A
airshot
replied to the thread
Building a fishing boat.
That sounds expensive and high tec......
Wednesday at 4:23 PM
reacted to
svb165's post
in the thread
06-5.7 mpi mag starts,, stalls, starts stalls. ran fine last fall
with
Like
Once I was able to get it scanned,,,,,,,,,,,,,,,,,, today. they replaced the map sensor and cleared the old codes. 35 min in and...
Wednesday at 4:21 PM
T
tphoyt
reacted to
tpenfield's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
Here is an interesting chart. I compared the speed vs RPM of the 'standard' CY338 Outboard (Bracket) with my boat CY338 with extension...
Wednesday at 4:20 PM
B
boscoe99
Ohm specs
What is the motor doing or not doing?
Wednesday at 4:12 PM
dwco5051
Is this possible?
48 500ml bottles on both tires. If 1/3 of them are under the water that would be less than 18 pounds of buoyancy. Plus no chain and no...
B
boscoe99
Ohm specs
All of the Yamaha specifications can be found in the applicable service manual...
reacted to
svb165's post
in the thread
with
Like
Wednesday at 4:11 PM
dwco5051
posted the thread
Is this possible?
in
Dockside Chat
How does she do it? https://www.facebook.com/reel/2433261573827937
Wednesday at 4:10 PM
BWR1953
Boat landing lights
I found the video on YouTube, in case anyone's interested. 613 actual comments on the FB page.
Wednesday at 4:01 PM
S
svb165
1989 omc cobra gear case problem
Check the shift interupt switch. make sure its activating correctly. I've had to slightly bend the switch arm on a couple boats over...
Wednesday at 3:59 PM
Wonder what your curve will look like with 18p props
Wednesday at 3:36 PM
P
Pmt133
Two questions. Do you think the the apparent (I say that only because of the lack of top end RPM in current configuration and any...
Wednesday at 3:28 PM
flashback
I like that, for me it would be perfect getting up that slow. :)
Wednesday at 3:27 PM
flashback
reacted to
tpenfield's post
in the thread
with
Like
Yes, my boat planes out at about 18 mph . . . the 'stock' 338 OB has to get up around 23 mph.
Wednesday at 3:25 PM
D
Dalejam
Need HELP identifying motor first
So I posted some pictures, can you tell from them about what year or model ? Thanks Dale
Wednesday at 3:22 PM
