P
Pmt133
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
In my defense, my role at work has been transitioning more and more to asking questions... so I'm just in a questioning mood lately. I...
Yesterday at 7:03 PM
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
You guys ask a lot of questions . . . some are above my pay grade and it may be a matter of trying things and see what works. My main...
Yesterday at 6:57 PM
K
Kissdude
1986 Mercury 9.8 110 outboard
So if the ignition is capable of jumping 3/8" then is it safe to say the cdi box is ok? I still can't get this thing to back or anything.
Yesterday at 6:56 PM
metalchewy
Building a fishing boat.
We've even toyed with hanging a lantern above the bamini. I will remember to put the spotlight in the dry bags when packing up. Won't...
Yesterday at 6:53 PM
metalchewy
reacted to
airshot's post
in the thread
with
Like
That sounds expensive and high tec......
Yesterday at 6:48 PM
metalchewy
reacted to
dingbat's post
in the thread
with
Like
See more and more guys using FLIR for running in low light conditions. Supported by a number of Ethernet compatible chartplotters and MFDs
aspeck
Is this possible?
Even if it wasn’t AI, I know I would sink it!
Yesterday at 6:30 PM
aspeck
reacted to
dwco5051's post
in the thread
Is this possible?
with
Like
48 500ml bottles on both tires. If 1/3 of them are under the water that would be less than 18 pounds of buoyancy. Plus no chain and no...
Yesterday at 6:28 PM
aspeck
Boat landing lights
That is cool, but the lights are running the wrong way … should be coming in, not going out … and the right starboard side should be...
Yesterday at 6:27 PM
nola mike
1. Do you have that graph from your old setup? 2. I'd like to see an MPH x Time graph...wonder if they'd still overlap EDIT: Oooh...
Yesterday at 6:12 PM
aspeck
Best story on the news tonite...
That is hilarious! The squirrel has moves. Squirrel could be hired as a base running coach to teach them how to beat out a rundown!
Yesterday at 6:08 PM
D
DeepCMark58A
Boat landing lights
I see the value of the lights, that garbage music cranked up is either rude or stupid. Noise pollution. I will say any loud music that...
Yesterday at 5:54 PM
K
KM7
posted the thread
How Do I remove the Thermostat from the Housing, Ford 5.8
in
OMC I/O & Inboard Engines & Outdrives
How do I remove the thermostat from the housing on a 91 Ford 5.8? The shop manual only says, "The Thermostat is held in place with an...
Yesterday at 5:53 PM
S
stpenroute
reacted to
Don S's post
in the thread
Where does the purple/white wire go?
with
Like
Re: Where does the purple/white wire go? When the purple/white wire isn't connected to anything, it's not grounded. To ground it you...
Yesterday at 5:48 PM
S
stpenroute
reacted to
Don S's post
in the thread
with
Like
Re: Where does the purple/white wire go? When you aren't grounding it for adjustments, then it just sets there, unhooked and does...
