metalchewy
replied to the thread
Force 2 cylinder throttle cable adustments
Tried pulling it up last night and it wouldn't budge. Will try again tonight after work.
Today at 1:19 PM
K
Kissdude
1986 Mercury 9.8 110 outboard
I have been using new coils I had on hand that I didn’t need for another motor so those are good. Does the choke need adjustment if it...
Today at 1:17 PM
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Yes, I was going to pull those numbers. The boats they tested back then had the V-P engines, but pretty much the same. One thing the...
Today at 1:16 PM
N
Nordin
My experience of these Mercury is that the ignition coils goes bad. They spark in atmosphere at plugs and with a spark tester. But if...
Today at 1:11 PM
dingbat
Should my telltale always be cool?
Depends on the water temperature and whether or not the tell tell is in parallel or in series with the cooling loop Your not generating...
Today at 1:09 PM
K
KM7
How Do I remove the Thermostat from the Housing, Ford 5.8
The thermostat seems to be working fine. With the housing off the engine. the spring is holding it closed. The engine warms up and then...
Today at 12:58 PM
N
Nordin
reacted to
racerone's post
in the thread
with
Like
If it does not bark with fuel in plug holes , you do not have STRONG spark or spark at the right time.----Flywheel key sheared ?
Today at 12:57 PM
N
Nordin
reacted to
jimmbo's post
in the thread
with
Like
Good? Spark at the plug at Atmospheric Pressure means nothing. Can it jump a gap of 3/8"?
Today at 12:57 PM
dingbat
Mercury oil injection - keep or delete?
Hoses get "stiff", lose plasticity as the result of prolonged exposure ultraviolet rays (sunlight) and atmospheric ozone breaking down...
Today at 12:50 PM
K
Kissdude
I was able to get the reed block all lined up with the pin to block
Today at 12:47 PM
K
Kissdude
Ok. so I was able to get her to fire for like 2 seconds with premix in the spark plug hole. Now what?
Today at 12:46 PM
FLATHEAD
Trail camera issues fixed, now pics....
Today at 12:39 PM
old pictures
Grade school classmate posted this on facetube the other day I'm the ugly cuss in the bottom RH corner
Today at 12:38 PM
FLATHEAD
reacted to
BWR1953's post
in the thread
old pictures
with
Like
Night Life 1972 It was warm 1972 summer evening and I was a 19 y.o. kid working at a Lum's Restaurant as a cook in Sandusky, OH. 👨🍳...
Today at 12:38 PM
D
DeepCMark58A
Rotted Plywood Edges
Buy exterior grade seal it install new, do not HA it. Once it starts getting soft it spreads.
Today at 12:36 PM
