  • S
    Steve51 replied to the thread Flushing bags.
    Looks like muffs it is. I would have difficulty getting a bag or tank with the right dimensions anyway as I have spent hours...
  • S
    Steve51 reacted to alldodge's post in the thread Flushing bags with Like Like.
    Flushing bags are for outboards, the impeller is in the leg and there is no issue with it moving water. The I/O needs water pushed to it...
  • Scott Danforth
    "The most common error of a smart engineer is to optimize a thing that should not exist."...... Elon Musk
  • alldodge
    alldodge replied to the thread Flushing bags.
  • redneck joe
    redneck joe replied to the thread Flushing bags.
    I know every mercruiser i have owned regular muffs were fine i know nothing of B3 but would assume the same. Others will have specific...
  • S
    OK this is where it gets complicated. This is a re-power with a brand new engine and sterndrive. I need to know whether the engine...
  • redneck joe
    i googled it. How do you get water to it currently? And seems like you would have to change the water a couple times or you are just...
  • matt167
    matt167 replied to the thread Digital permanent dwell readout..
    I do the same. I just checked it Saturday and it was spot on still from last year. It is a 75 year old car with a 75 year old engine...
  • C
    Chris1956 replied to the thread Water in lower unit.
    Here is the seal for the shift shaft https://www.crowleymarine.com/mercury/products/77631a2-shift-shaft-bushing-assembly
  • C
    Mine leaked twice thru the shift rod seal. The obvious other place is the driveshaft seal in the waterpump base. If you have one of...
  • S
    The flushing bag covers the propeller shaft and water intake holes in the sterndrive leg allowing flushing of saltwater with clean fresh...
  • redneck joe
    never heard of a flushing bag, assume it dumps into the topside of the motor since you have not used muffs before. Can you not move...
  • redneck joe
    or small claims. Grab a screenshot of the ad.
  • jimmbo
    jimmbo replied to the thread 1980 110(9.8) hp Mercury outboard.
    On larger engines, almost all the timing advance is in before the carb is even cracked off of idle, and then once max advance has...
  • ranger335
    OK. Just what I saw.
