replied to the thread
2005 bravo 3 leak but no leak
ok, check the lube hose between transom and bell housing
Aug 19, 2026
dingbat
reacted to
tphoyt's post
in the thread
There almost here
with
Like
When I lived in Fl they would come come up Into the canals in the winter for the warmer water and even then they didn’t move much. They...
Aug 19, 2026
dingbat
There almost here
From the article… Since December 2020, about one-quarter of the species’ population has died during what federal wildlife officials have...
Aug 19, 2026
reacted to
Lou C's post
in the thread
When do you replace the bellows? '01 Alpha One Gen 2
with
Like
Get a bright LED flashlight, tilt it all the way up & look for cracks in the rubber. You’ll probably see a lot of tiny cracks in the...
Aug 19, 2026
reacted to
redneck joe's post
in the thread
with
Like
replace, shift boot as well
Aug 19, 2026
reacted to
Scott Danforth's post
in the thread
with
Like
Inspect them However at 26 years, you're well past design and service life
Aug 19, 2026
Lou C
Try again but turn the prop shaft while checking pressure. When I check my OMC Cobra I use the shift rod to shift in gear while turning...
Aug 19, 2026
Lou C
Aug 19, 2026
T
tphoyt
There almost here
Aug 19, 2026
2
2009 stingray
yeah i inspected all the parts inside the boat before pulling the boat and there is no gear oil leaks in the engine compartment and the...
Aug 19, 2026
redneck joe
Aug 19, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
I've been working on anothe truck hood while waiting for that flake.
Aug 19, 2026
Aug 19, 2026
2003 5.7 Volvo Penta water in oil
You visually inspect the gaskets and gasket surface between the two, and you fill the manifold with acetone (seeps thru smaller cracks)...
Aug 19, 2026
reacted to
jimmbo's post
in the thread
Piston soaking a 2 cycle outboard?
with
Like
BRP Engine Cleaner or Mercury's Engine Tuner, are 2 of the better Ring unstickers in 2 strokes. CRC gdi ivd intake valve cleaner is also...
Aug 19, 2026
