jimmbo
replied to the thread
Prop nut for Merc 25 hp?
Lots of SS Props and AL Props use the same Prop Nuts, so who knows....
Aug 20, 2026
R
Need Replacement Lower Unit for Evinrude E70PL4EEC, 70HP,4 stroke, 1999 rebuilt or new
Contact----evinrudeparts.ca----Located in Ontario.-----Explain that you have a SUZUKI built motor.-----Parts for a 1999 Suzuki are...
Aug 20, 2026
nola mike
I was thinking that as a reason not to use SS nut with aluminum prop, but brass nuts are commonly used on both, no? Yes, for why nylon...
Aug 20, 2026
W
workboot
200hp efi overheating
thanks for the reply, I did not check for flatness, I have a diagram in my service manual for where they go, I did get an overheat alarm...
Aug 20, 2026
2
2009 stingray
2005 bravo 3 leak but no leak
ok, ill check that next thank you
Aug 20, 2026
Lou C
2003 5.7 Volvo Penta water in oil
There is a pipe plug on top of the exhaust elbow. If you can remove this you can snake an endoscope camera inside and know for sure if...
Aug 20, 2026
reacted to
Scott Danforth's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
Tap method doesn't work until long after the wood is wet, rotten, and eaten by insects, then dries out leaving a void Chuck up a 5/16"...
Aug 20, 2026
3.0 mercruiser engine
Ayuh,..... What other engine,.??..??
Aug 20, 2026
Alpha 1 Gen 2 shift question
Normally the throttle shift cable doesn't go bad because the throttle just moves a tad more to complete the shift. What kind of shift...
Aug 20, 2026
Nice work
Aug 20, 2026
J
jclark178
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Anyone ever substitute a 3.0 engine with another engine, if so what type and what changes did you make
Aug 20, 2026
dingbat
Woods 9180RD Batwing came apart
You got to love working on farm equipment. Bush hogged the back pasture Sunday morning. Got back to the barn… the tail wheel assembly...
Aug 20, 2026
M
MikeSchinlaub
reacted to
tpenfield's post
in the thread
with
Like
Looks good. Keep in mind that Coosa is not as strong as plywood, so you will want to double up on the glassing of those stringers.
Aug 20, 2026
C
SEI is Sterndrive Engineering. They make replacement parts and gearcases for popular motors.
Aug 20, 2026
C
Distance from lower gear case to prop
Are the splines holding the prop in that spot? I had to drill out some of the splines on my Merc prop to make it fit the Johnnyrude.
Aug 20, 2026
