D
DeepCMark58A
reacted to
Pmt133's post
in the thread
rant
with
Like
First words out of my mouth "what do you need me to bring?"
Aug 24, 2026
D
DeepCMark58A
replied to the thread
New project
My son will not be up to water ski, it's the only time the boat gets used is when he is up, it really isn't a pleasure boat the...
Aug 24, 2026
M
muc
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
It sounds like you have checked the drive all you can, suggest you clean the water passages, install new impeller and test run the...
Aug 24, 2026
M
mike_i
What is the Best Way to Repair the Snaps on a Sunbrella Cover
Luckily a neighbor has a heavy duty sewing machine and has been able to sew patches and fix tears in my sunbrella cover. I've tried...
Aug 24, 2026
B
bigbadchevy89
1969 buick 225 oddfire
Damn I was hoping someone found what I couldn't
Aug 24, 2026
B
bigbadchevy89
Definitely
Aug 24, 2026
B
bigbadchevy89
I can get that. My springs and everything are tired on my advance. I was hoping to not mess with them.
Aug 24, 2026
W
workboot
200hp efi overheating
yes, a rubber O-ring around each piston and a bigger rubber gasket around the perimeter of the head and I replaced all of them
Aug 24, 2026
M
muc
I was mainly pointing out that you aren't allowing the engine to run at WOT at a steady state long enough to get valid results. Optimal...
Aug 24, 2026
P
Pmt133
Tinkering on the 4.3l this winter...
Dad spent the weekend at the lake with it, was very very pleased with its performance with the 4 barrel. With 6 people on board I did...
Aug 24, 2026
M
muc
I just mentioned the gear lube because it didn't look like what I'm used to seeing, I can't say if it will cause you issues. It appears...
Aug 24, 2026
C
Question regarding wiring up a carter electric fuel pump
Gee, a lot of folks likely do the upgrade like you. Can you get a new wiring harness for your motor with the electric fuel pump wiring?
Aug 24, 2026
C
OK, so it sounds like no water is getting into the combustion area. That does not mean that compression is not getting into the cooling...
Aug 24, 2026
J
Jeff J
Any clue what this gunk is?
If water can get in then oil can come out, especially if there is enough water is getting in to push the oil out. I pulled a gear case a...
Aug 24, 2026
Lou C
I just bought a 2025 Bayliner VR5 with the 200hp 4.5L Mercruiser, - many issues - Low power, BARELY pulls me up slalom
Stalling while idling doesn't have anything to do with the swim platform issue, that is a boat fuel system problem or a Mercruiser EFI...
Aug 24, 2026
