C
replied to the thread
Deep pitting inside water jacket on power head.
Whereas Yamaha has several anodes in the engine, I never saw the same in a Merc. Mercs have their anodes on the transom bracket and...
Aug 26, 2026
dingbat
Stainless Steel Rowboat
Guess I need to increase the txt size on my phone.. Yep, you are correct. It would be lighter than stainless steel
Aug 26, 2026
Horigan
reacted to
JustJason's post
in the thread
Question regarding wiring up a carter electric fuel pump
with
Like
Technically it does, but only after the engine has started, not before the engine has started. But the power is on the bypass terminal...
Aug 26, 2026
Bt Doctur
posted the thread
cool fuel III interesting trouble
in
Mercury MerCruiser Sterndrives & Engines
Got my hands on a unit that a shop had replaced because of a fuel problem. The unit was not cooling the fuel leading to some issues...
Aug 26, 2026
K
kalebsheridan
Awesome I'll try that. Anything that can be done to prevent further pitting or corrosion? I thought the anodes where supposed to prevent...
Aug 26, 2026
J
Jeff J
reacted to
DeepCMark58A's post
in the thread
with
Like
I would be tempted to believe what the decal says on the side of the boat.
Aug 26, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
Since I was checking the valve springs, I also verified the valve timing. For cylinders 1 and 4, the intake valve pushrod lift begins at...
Aug 26, 2026
R
reacted to
Jeff J's post
in the thread
with
Like
I think that is backwards. Magnesium is less dense so the same amount would be lighter.
Aug 26, 2026
J
Jeff J
Aug 26, 2026
Boats from work.
it outlasted campion 6 times over...... LOL (cuz they are bankrupt and shuttered again)
Aug 26, 2026
cupped prop question
cupping adds performance so removing the cup will decrease performance relieving the cup a bit should get you the 200 RPM you are...
Aug 26, 2026
J
jlh3rd
posted the thread
in
Prop Questions and Topics
I have an aluminum Merc. 4 blade 14x14 that gives me 5800 rpm @ WOT. I want 6000. There is no 4-14x13 that fits my motor (4 3/4...
Aug 26, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Aug 26, 2026
M
MikeSchinlaub
Boats from work.
Yeah, the bottom side of the floor isn't even sealed, but still surprisingly solid behind where I cut yesterday. The thing is pretty...
Aug 26, 2026
redneck joe
Random
Aug 26, 2026
