J
Jeff J
replied to the thread
Mismatched surge brake components
I don’t know weight range of your boat but it seems like a lot of 21’ and smaller ski boat owners and most pontoon boat owners around...
Aug 26, 2026
M
Mohawkmtrs
Honda B100L outboard fuel pump ?
I've got a blown Honda BF8AX that has the same fuel pump (and a tiller handle) and live near Toronto (2 hrs). Contact me privately (use...
Aug 26, 2026
K
kool breeze
posted the thread
in
Trailers and Towing
Hello, I have a tandem boat trailer that I had to replace the actuator and calipers. It's turned into a complete sht show. The...
Aug 26, 2026
redneck joe
Used Glastron GX 205 with engine issues
old boat, wood substructure can rot and not be noticed. That is first concern on a 25 year old boat.
Aug 26, 2026
dwco5051
reacted to
Scott Danforth's post
in the thread
with
Like
you can do the work yourself and swap the motor for $5500 for a new 5.7 liter motor or much much less if you understand motors and...
Aug 26, 2026
Aug 26, 2026
K
kalebsheridan
Deep pitting inside water jacket on power head.
Very interesting. This is actually a Yamaha built mariner, so kinda confusing. I'll look more on the block for an anode but I'm not...
Aug 26, 2026
Yamaha T9.9 no power to starter
pull the starter and bench test it
Aug 26, 2026
Fun Times
Mariner 40E 6E9 S 103761 Can't find a definitive year or manual
Merc service manual part number 90-84520-2 / 190 Covers 40A (676-A)/40B (676-B) 40C (6E9)/W40 (676-A) (I) All Serial Numbers.
Aug 26, 2026
M
Mohawkmtrs
As per Brunswick Marine: Mariner Japan Sourced 1974-1992: 6E9 102889 1984 6E9 103919 1985 Your Mariner (6E9 S...
Aug 26, 2026
F
Ferrarakias
Lower unit won't shift after Impeller change
If you do align both the lower shift shaft (all the way anticlockwise) and control in reverse and reassembly, what will be the problem...
Aug 26, 2026
flashback
reacted to
Bt Doctur's post
in the thread
cool fuel III interesting trouble
with
Like
Got my hands on a unit that a shop had replaced because of a fuel problem. The unit was not cooling the fuel leading to some issues...
Aug 26, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Random
with
Like
Had a surprise visitor yesterday. I was just starting on the truck when I see a brown and white blur. Turns out, it was this guy...
Aug 26, 2026
M
mike_i
Aug 26, 2026
Lou C
I’d think that’s common on boats that often run in shallow water and here in the salt pond I wound not be surprised to find crud growing...
Aug 26, 2026
