J
Jmunk
replied to the thread
Power Steering Pump - Angled Mount
I ended up putting two stainless washers on the lower stud for a total of 1/8”. With it back together it’s better, probably could have...
Aug 26, 2026
reacted to
Bondo's post
in the thread
Used Glastron GX 205 with engine issues
with
Like
Ayuh,.... I posted in yer thread over at marine engine com,.....
Aug 26, 2026
M
muc
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
Cam Lobe Lift looks right. But as far as the other measurements --- I have no idea. Mercury doesn't publish any of these numbers. Also I...
Aug 26, 2026
reacted to
alldodge's post
in the thread
cupped prop question
with
Like
There is always a give take between max RPM achievable and max RPM performance increase. Gaining that last 200 RPM may not gain any...
Aug 26, 2026
reacted to
Chris1956's post
in the thread
with
Like
Gee, most props are cupped. Is your 14P prop cupped? if so, changing the pitch to 13P cupped prop should give you the 200RPM you want...
Aug 26, 2026
Aug 26, 2026
No such thing as fuel efficiency. It's BSFC. Most 4-strokes burn 0.4#/HP/hr
Aug 26, 2026
NEVER turn a Chevy motor over by the crank pulley. The bolt will strip out the threads in the crank and you then have junk Always use...
Aug 26, 2026
nola mike
reacted to
Bt Doctur's post
in the thread
cool fuel III interesting trouble
with
Like
Got my hands on a unit that a shop had replaced because of a fuel problem. The unit was not cooling the fuel leading to some issues...
Aug 26, 2026
9
99yam40
Sand getting into Suzuki 20hp outboard - can I pull it out?
I have no idea what you mean it seems a big tighter. can you explain? even if you meant a bit tighter, I have no idea what is tighter...
Aug 26, 2026
K
kalebsheridan
Deep pitting inside water jacket on power head.
I was just thinking about that. It just needs to make metal to metal contact with the block right?
Aug 26, 2026
R
Relentless85
Is there a way to turn the motor over by hand? When I was looking at the crank pulley, it looked like there was a water pump covering...
Aug 26, 2026
dingbat
Mismatched surge brake components
Lots of different brand names are in fact the same parts. Who was the OEM of the orginal calipers and pads?
Aug 26, 2026
dingbat
reacted to
Mc Tool's post
in the thread
Stainless Steel Rowboat
with
Like
😁Yeah , I wasnt going to say anything this time 😆😆
Aug 26, 2026
J
Jeff J
Fuel efficiency takes a pretty big hit when max torque falls off as well.
Aug 26, 2026
