2009 stingray
posted the thread
V/P osxi-G 5.7 lack or power and 1 beep every 5-7 seconds
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
hey all, i got a bugger hear, took over this job after the owner felt their mechanic was just throwing parts at this problem, . no...
Aug 27, 2026
J
justin4530
replied to the thread
1962 Evinrude 40hp Lower Unit Leak?
Thanks for the input, thinking back on it I was idling it for a long time messing around with the adjustments and letting it get up to...
Aug 27, 2026
M
MikeSchinlaub
1997 Bayliner Capri Stringer and Floor Repair
Just wait till you start grinding, they'll love that.
Aug 27, 2026
2
2009 stingray
reacted to
Bt Doctur's post
in the thread
cool fuel III interesting trouble
with
Like
Got my hands on a unit that a shop had replaced because of a fuel problem. The unit was not cooling the fuel leading to some issues...
Aug 27, 2026
H
Harkonnen
2003 Johnson 115 – Vacuum/Bypass Hose Diagram & Check Valve Elbow (P/N 0437784) Question
Any luck so far? Had the same problem with 2005; if you still need it, I can look for the diagram.
Aug 27, 2026
S
sailorboi
posted the thread
1974 55hp Chrysler 557HG ignition timing
in
Force & Chrysler Outboards
Hey y'all, I recently bought a 1979 starcraft with a 1974 55hp 557HG Chrysler outboard (Alternator version). The previous owner messed...
Aug 27, 2026
A
airshot
Just cant figure this out...
Gumout was on the market long before E fuels were even created. So yes non E fuels can gum up a carb. What folks have not yet accepted...
Aug 27, 2026
S
SteveD78
Ya I read somewhere about having to block it. Neighbours are gonna love me 🤷♂️. Something else to learn.
Aug 27, 2026
S
SteveD78
I pulled mlre today to try and get a better look. Still figuring out how to do the seats without having to rebuild all that as well.
Aug 27, 2026
S
SteveD78
Ya, cost is not really the worry, it's the time it will take and not having a heated shop to work in over the winter. Also, spending...
Aug 27, 2026
S
SteveD78
Aug 27, 2026
C
Crosbyman
first it held pressure so next is a vacum test...... but i would not rush a seal job if you recheck gear oil for water ingress ...
Aug 27, 2026
Scott06
My block is drained, right?
Willing to bet it siphoned through the block water pump and drained out other side or J hose
Aug 27, 2026
Scott06
non alcoholic beer
In Germany very common to mix sprite with helles (standard German lager) it’s called a Radler. Which basically means one who rides his...
Aug 27, 2026
J
jlh3rd
cupped prop question
yep
Aug 27, 2026
