K
Kosmofreeze
reacted to
Lou C's post
in the thread
Sand Ingestion - DP-SM
with
Like
IIRC there is a clean out on the SX upper unit, under the plastic cover. Once it gets in the engine it's tough to get it out. GM cast...
Aug 28, 2026
K
Kosmofreeze
reacted to
Scott Danforth's post
in the thread
with
Like
do you have a heat exchanger, or are you raw water cooled. 1 of 3 things happen when you bury a VP drive in the sand. its light sand...
Aug 28, 2026
K
Kosmofreeze
reacted to
Bondo's post
in the thread
with
Like
Ayuh,...... When you change the impeller, flush from there, backwards out to the drive,.... When you drain the block, pull the plugs...
Aug 28, 2026
B
bakerjw
replied to the thread
Stratos 1850 CC Rebuild Part 2
Transom Insanity! Well, I had some air voids when I did the transom the last time and it came back to bite me as seen here. Lessons...
Aug 28, 2026
B
bakerjw
Picture time. Been too busy to be posting. Stratos made their boats with a 2 part construction method. The hull was built out with a...
Aug 28, 2026
B
BOYS & TOYS
reacted to
IslandExplorer's post
in the thread
1974 Chieftain 25 "Adventurer" Restoration
with
Like
Been real, real hot this summer. Had to throw an AC in temporarily to keep the productivity up. Time to make electricity do some work...
Aug 28, 2026
FLATHEAD
reacted to
in the thread
non alcoholic beer
with
Like
The list of bad beers that have a lot of advertising to get you to drink the swill is long My favorite beer is a local micro that's in...
Aug 28, 2026
FLATHEAD
non alcoholic beer
How true that is. Guy over in town has a tiny store front brewery. Brews a nice beer.
Aug 28, 2026
T
tphoyt
reacted to
in the thread
non alcoholic beer
with
Like
Aug 28, 2026
B
bakerjw
Repair of door latch
Can you finagle a piece into that void and slide it up? Can you post a picture showing the entire area?
Aug 28, 2026
Grub54891
reacted to
FLATHEAD's post
in the thread
Trail Cam pix......
with
Like
This guy is out of velvet. Couple weeks early archery opens up.
Aug 28, 2026
non alcoholic beer
Aug 28, 2026
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Boat? What boat? I've never seen one, I don't even know what a boat is...
Aug 28, 2026
Problem with just a backer plate is I'll need to cut about 1/4 inch further up and there isn't much there now
Aug 28, 2026
S
sailorboi
reacted to
Nordin's post
in the thread
Timing marks on fly wheel.
with
Like
There should be two marks at the flywheel. One is 36 dgr BTDC and the other is 0 drg (TDC) for top cylinder. Are there only two marks at...
Aug 28, 2026
