M
MikeSchinlaub
reacted to
bakerjw's post
in the thread
Stratos 1850 CC Rebuild Part 2
with
Like
Transom Insanity! Well, I had some air voids when I did the transom the last time and it came back to bite me as seen here. Lessons...
Aug 28, 2026
M
MikeSchinlaub
reacted to
bakerjw's post
in the thread
with
Like
Picture time. Been too busy to be posting. Stratos made their boats with a 2 part construction method. The hull was built out with a...
Aug 28, 2026
C
crazy charlie
posted the thread
Yamaha SX200 fuel filter replacement universal?
in
Boat Topics and Questions (not engine topics)
https://www.walmart.com/ip/GHmarine-Fuel-Filter-Element-for-Yamaha-outboard-F-150-200-225-250-HP-Outboard-65L-24563-00/3113971678. Are...
Aug 28, 2026
Lou C
replied to the thread
Questions about the set up of a Holley 4160 on a 4.3 V6
Won’t fit on a 4.3 the front fuel line will hit the thermostat housing. The 4.3 used the side mount fuel inlet.
Aug 28, 2026
jimmbo
VP used the 4175, a spreadbore, to replace the Q-Jet
Aug 28, 2026
P
Pmt133
non alcoholic beer
I ignore it.
Aug 28, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
TDC was correct confirmed with inspection camera. First set best what I saw on camera and then checked TDC. Emailed Merc but seems that...
Aug 28, 2026
Lou C
posted the thread
in
Non-Repair I/O and Inboards
Ok guys, my Quadrajet acted up again over the past 2 seasons, not running right, I had it all apart, tried to clean it the best I could...
Aug 28, 2026
dingbat
non alcoholic beer
So the "no pump" law isn't real or you just ignore them? Got to admit, never got gas in NJ other than on the turnpike
Aug 28, 2026
dingbat
reacted to
FLATHEAD's post
in the thread
non alcoholic beer
with
Like
Pa has a two tier liquor license requirement. A bar can get a limited license for only hundreds of dollars that allows them to serve...
Aug 28, 2026
Lou C
Replacing Risers/Elbows and Exhaust Manifolds on a Ford/OMC Cobra 5.8 Ltr
Don't your old manifolds have that fitting? Mine original ones fit the threads in the Barr manifolds. Ahh just checked them, looks like...
Aug 28, 2026
reacted to
bakerjw's post
in the thread
Repair of door latch
with
Like
What Mike said. Might be able to remove some of the wall behind it. Just for some maneuvering room.
Aug 28, 2026
reacted to
MikeSchinlaub's post
in the thread
with
Like
This is what I'm thinking. Make a backer like the yellow square, push it through the large hole and maneuver it into place. Use some...
Aug 28, 2026
reacted to
Scott Danforth's post
in the thread
with
Like
hit the autobody supply store near you. get a pint or quart of tiger hair filler. then fill the voids and give the screw something to...
Aug 28, 2026
B
bakerjw
Aug 28, 2026
