tpenfield
replied to the thread
Retirement Financial Planing
One thing that I tell young people, family & friends, etc about retirement planning, which largely amounts to savings, is that you...
Aug 29, 2026
reacted to
tpenfield's post
in the thread
with
Like
FWIW - I found this video fairly interesting as it discusses the subtle differences in what it takes to climb the 'wealth ladder' into...
Aug 29, 2026
Sand Ingestion - DP-SM
Ayuh,..... There's little to no chance of that, with a good functioning system,..... If yer that worried 'bout it, after doing so...
Aug 29, 2026
P
Pmt133
I'm looking to do a partial retirement around 50.... Still work but either go to part time or consulting. Depending on what I am doing...
Aug 29, 2026
K
Kosmofreeze
Mine is raw water cooled so no heat exchanger to plug up. I'm leery of using a hose to flush out any sand for fear of flooding the...
Aug 29, 2026
K
Kosmofreeze
posted the thread
Gelcoat Shelf Life
in
Boat Restoration, Building, and Hull Repair
I have a few "blemishes" on my Atlantic Blue hull and am going to give it a go to repair them myself. I probably need less than 2-4 oz...
Aug 29, 2026
Texasmark
What kind of boat is this?
I had several of them when they were popular....1970-80's. It's a trim-hull and I didn't like mine especially for Sunday trips after...
Aug 29, 2026
nola mike
Your gross income can be higher before you hit the highest tax bracket
Aug 29, 2026
S
SeaRayboater95
posted the thread
Shift cable adjustment
in
Mercury MerCruiser Sterndrives & Engines
Mornin' Guys and Gals I just repaced all bellows and lower shift cable on a1996 Alph1 Gen 2. I did all the adjustments as described in...
Aug 29, 2026
C
Crosbyman
2003 Johnson 115 – Vacuum/Bypass Hose Diagram & Check Valve Elbow (P/N 0437784) Question
https://watercraftmanuals.com/outboard/johnson/johnson-5005463.htm easy downloads if anything like the johnson manual for oldies...
Aug 29, 2026
Repair of door latch
ok will reassess
Aug 29, 2026
That is a great vid and would be great to show in high school junior and senior
Aug 29, 2026
T
tphoyt
If were me I would just fill the holes with an epoxy filler and drill and tap and use machine screws and lock tight. Done
Aug 29, 2026
M
MikeSchinlaub
reacted to
redneck joe's post
in the thread
Random
with
Like
Aug 29, 2026
J
jlh3rd
popular back in the late 70's - 80's. My brother had one. They'll beat the heck out of you at speed even in a relatively calm lake.
Aug 29, 2026
