replied to the thread
Questions about the set up of a Holley 4160 on a 4.3 V6
Ayuh,.... I believe that's unnecessary,...... I've run both types, with no differences, at all,....
Aug 29, 2026
reacted to
Scott Danforth's post
in the thread
Sand Ingestion - DP-SM
with
Like
A few years back I posted a few flushing nozzles that I made for going in the drain plugs Basically this adapter and a section of 1/4"...
Aug 29, 2026
reacted to
kenny nunez's post
in the thread
Have an old OMC Stringer + engine... what to do with it?
with
Like
Try to post some pictures of what you have so that it can be identified.
Aug 29, 2026
S
SeaRayboater95
Shift cable adjustment
Pretty sure. It moves freely when not attached to shift bracket.
Aug 29, 2026
B
bakerjw
Gelcoat Shelf Life
What brand of gelcoat? If not generic, ask the manufacturer.
Aug 29, 2026
Berdink
What kind of boat is this?
Yeah, I've been reading they are stable on stable water. 😊 The lady just wants it hauled off. Portland Oregon area.
Aug 29, 2026
B
Boaterdan278michigan
Boat purchase
Owners say they cannot provide maintenance records. They name off several maintenance they've done, water pump impellers, engine oil...
Aug 29, 2026
B
reacted to
airshot's post
in the thread
Boat purchase
with
Like
The surveyors I have known do everything unless it is a large boat. You need maintainence records and receipts as does the surveyor.
Aug 29, 2026
C
Crosbyman
1993 Johnson 9.9 lower cylinder wet.
deleted
Aug 29, 2026
Bt Doctur
Are you positive you didnt put a kink in the new cable
Aug 29, 2026
Fun Times
Mariner 40E 6E9 S 103761 Can't find a definitive year or manual
While i don’t believe there’s any real difference between the two years plus the variance of years suggested is sort of a long history...
Aug 29, 2026
A
Abefish0
Thanks for the insight. I removed the head and found a hole at the very bottom of the gasket that I believed was letting water into the...
Aug 29, 2026
S
SeaRayboater95
Will look into that thanks
Aug 29, 2026
B
boscoe99
More than likely not a dimes worth of a difference between a 1983, 1984 and 1985 40E model.
Aug 29, 2026
V/P osxi-G 5.7 lack or power and 1 beep every 5-7 seconds
One or more of the sensors is not reading correctly. You will most likely need a scanner to get close. Can take a voltmeter and measure...
Aug 29, 2026
