K
Kosmofreeze
reacted to
Bondo's post
in the thread
Sand Ingestion - DP-SM
with
Like
Ayuh,..... There's little to no chance of that, with a good functioning system,..... If yer that worried 'bout it, after doing so...
Aug 30, 2026
redneck joe
replied to the thread
Random
Aug 30, 2026
K
Kosmofreeze
reacted to
Jeff J's post
in the thread
with
Like
I pulled the exhaust off a Mercruiser a couple of years ago. There was zero chance the sand packed in there was coming out by flushing...
Aug 30, 2026
K
Kosmofreeze
reacted to
Scott Danforth's post
in the thread
with
Like
A few years back I posted a few flushing nozzles that I made for going in the drain plugs Basically this adapter and a section of 1/4"...
Aug 30, 2026
C
Crosbyman
Successful Deletion of VST, Primer, & Fuel Pump
Powering the FP from the regulator output with a few blocking diodes to prevent feedback B+ from the solenoid should do it & kill the...
Aug 30, 2026
C
80 HP Mercury trim
Do you have the PTT with the trim pump and reservoir in the boat? If so, you can have one or two solenoids. The UP circuit will...
Aug 30, 2026
Artificial Intelligence
The only AI I use is what's offered when I do a search for something, so far free
Aug 30, 2026
E
Earl Cordova
Ethanol!
If I could get E0 that is all I would purchase.
Aug 30, 2026
Ethanol!
Clean the carb and tank Ditch the stabil Then run the motor more often and drain the fuel system after use. Item 15 is the drain...
Aug 30, 2026
Cup420
posted the thread
Rebuilding carbs
in
Yamaha & Suzuki Outboards
I have a friend that says, I need to put something on the o-rings before installing them. Im questioning this decision, because all the...
Aug 30, 2026
I just saw an advertisement for an AI spam filter that uses AI. So people are now supposed to pay for AI to police AI.... If that...
Aug 30, 2026
Questions about the set up of a Holley 4160 on a 4.3 V6
Just run a wire from the coil to the choke toaster element
Aug 30, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
I also performed leak down test. First the cold engine readings were 25-32%. Then yesterday after waming up the engine and checking the...
Aug 30, 2026
D
damo79
I read more about props I have. Asked AI to compare them both and find Black Max equivalent. No wonder dropping prop pitch by 2" didn't...
Aug 30, 2026
Scott06
Used Glastron GX 205 with engine issues
This! My buddies similar vintage Glastron had a rotten transom due to Glastron mounting the swim ladder on the transom right at the...
Aug 30, 2026
