J
Jeff J
replied to the thread
Rebuilding carbs
I’m not familiar with that product. I keep a small tub of Vaseline in the shop.
Aug 30, 2026
J
Jeff J
Retirement Financial Planing
My truck is a 2008. Wife’s car is a 2014. No plans for swapping them out. I paid off the truck in 2010 but kept sending the payment to a...
Aug 30, 2026
Cup420
Rebuilding carbs
Could I use this?
Aug 30, 2026
B
Boaterdan278michigan
reacted to
airshot's post
in the thread
Boat purchase
with
Like
They should have reciepts, even if the work was done by the owner, there should be receipts for the materials. With no way to prove any...
Aug 30, 2026
A
airshot
Boat purchase
Aug 30, 2026
Burning valves and melting spark plugs 5.7 efi
Ayuh,..... I agree as well, but I'd start at the fuel tank, 'n inspect/ clean everything, all the way through the fuel system,.....
Aug 30, 2026
J
Jeff J
Are Yamaha fuel filters universal?
I didn’t know that. The database is a little suspect anyway, either that or a local dealer has no clue how to look up parts. I tend to...
Aug 30, 2026
tpenfield
We tend to keep our cars for 10-15 years. I always say . . . a paid-off car is like money in the bank :ROFLMAO:
Aug 30, 2026
B
Boat purchase
Thank you. The boat is in a covered slip. The boat is extremely clean. The engines are 5.7 L fuel injected. I did a cold start, engine...
Aug 30, 2026
Cup420
reacted to
Jeff J's post
in the thread
Rebuilding carbs
with
Like
I use petrolatum or the fluid the o-ring will be exposed (gasoline isn’t a good lube) to on nearly every o-ring I install. Oil and gas...
Aug 30, 2026
Cup420
Rebuilding carbs
I've replaced all the fuel lines, the bulb and added an in line fuel filter. I've also checked for compression and spark both were good...
Aug 30, 2026
tpenfield
Boat purchase
If the boat/engines reach their specifies RPM at full throttle and the boat speed seems reasonable/typical, then it is a good bet that...
Aug 30, 2026
Cup420
reacted to
racerone's post
in the thread
Rebuilding carbs
with
Like
Run fuel out of carburetors when motor sits for a week or more.----There is no need to " rebuild " a carburetor every season.----What...
Aug 30, 2026
nola mike
Crazy where you can save a ton of money if you want to... I ran a few scenarios about car ownership. 1. Buying a new average priced car...
Aug 30, 2026
B
reacted to
mr 88's post
in the thread
Boat purchase
with
Like
Blackstone and Amsoil have DIY oil analysis kits for 30-40 $ , compression gauge can be bought for 40-50 $ as well . If the boat is at...
Aug 30, 2026
