C
Cconway
reacted to
jimmbo's post
in the thread
What parts from a ‘77 Evinrude 85 are interchangeable with a ‘73 Evinrude 115?
with
Like
The Carbs on a 73 115hp are larger than the carbs on a 77 85hp, as the 115 has about 8-9% more displacement than the 85, and have a...
Aug 31, 2026
jimmbo
replied to the thread
Aug 31, 2026
JimS123
Used Glastron GX 205 with engine issues
I have been blessed in that every boat I ever bought was exactly what I wanted. And then they have always been meticulously taken care...
Aug 31, 2026
A
anthonyg163
reacted to
doral1985's post
in the thread
omc stringer 800 mechanical shif goes forward in reverse gear and reverse in forward
with
Like
I replaced the mechanical shift cable and it came with the shift housing attached, i also replaced shifter/ throttle control cables...
Aug 31, 2026
JimS123
Ethanol!
E10 is a big boon. When a mechanic can't figure out what the problem is (was), now he has something to blame. Lots of reading to be...
Aug 31, 2026
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
No, I need it. You can have all my anxiety though. 100% free!
Aug 31, 2026
reacted to
Scott Danforth's post
in the thread
2-4-C
with
Like
must have been a dealer or marina tech. Most cummins techs just reprogram the ECM if there is an approved change from the fuel systems...
Aug 31, 2026
bajaman123
2001 Mag MPI Alpha lugs
A true 350 Mag MPI is designed to run 4800 - 5200 rpm. My brother had this same engine in his Rinker. Something is VERY wrong with...
Aug 31, 2026
Jim Hawkins
F6 Yamaha Backpressure Issue???
I will do that although I want to note that with the rubber plug out the motor runs just fine, gets my little boat up on plane. I would...
Aug 31, 2026
Jim Hawkins
reacted to
99yam40's post
in the thread
with
Like
check compression, sounds like it is having a problem with the water back pressure when dunked(submerged)
Aug 31, 2026
A
AceDuece
1985 Johnson 25hp J25TELCOS firing half as often on bottom cylinder at idle
91psi cold on both cylinders. Reading is from a gauge that consistently reads low as well, so guessing probably 100ish.
Aug 31, 2026
K
kirkj
I checked the timing and it's at 8 btdc and it advances about 34 degrees with throttle. This was on my driveway though. I will get a...
Aug 31, 2026
T
The nut
reacted to
dwco5051's post
in the thread
Need help! Mind of its own Johnson gt150😬
with
Like
My numbers were all in the low 90's not to long after a complete rebuild. I was told not uncommon on those old crossflows.
Aug 31, 2026
redneck joe
80 HP Mercury trim
when you figure out what you have i can dig a bit deeper in the trouble shooting but based on your post i'm guessing a dual solenoid set...
Aug 31, 2026
redneck joe
80 HP Mercury trim
Aug 31, 2026
