redneck joe
replied to the thread
The head
Simple Scott - thats his new name...
Sep 1, 2026
B
bakerjw
reacted to
Pmt133's post
in the thread
Bringing a bubble buster back to life.
with
Like
If it's all metal, just toss in an oven at 300. We had some lab equipment you had to epoxy a test sample to. When finished you had to...
Sep 1, 2026
B
bakerjw
Nope. Nylon...
Sep 1, 2026
R
Electric car.
Leasing is best.-----You can't lose nearly as much as buying one.-----They lose value very quickly.
Sep 1, 2026
FLATHEAD
posted the thread
Electric car.
in
Dockside Chat
Took our caddy in for a leaking seal under warranty. They gave me a brand new fully loaded Lyriq for a loaner,8 miles on the clock. I...
Sep 1, 2026
JonBoat55
Alpha One Gen 2 Outdrive Mystery
All oil seals need to be under pressure and have shift/shaft motion at the same time to pass. These leaks can be sneaky
Sep 1, 2026
JonBoat55
reacted to
Pmt133's post
in the thread
with
Like
My shift shaft seal "passed" a pressure test until you simulated shifting, then it started to leak.... very slowly. Definitely worth...
Sep 1, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
I got the auto choke all hooked up since I had the relay set up last time that’s what I went with this time. The old divorced choke...
Sep 1, 2026
Texasmark
Water pump rebuild after 11 years and 600 hours
On my last boat I had a temp gauge and as you, I could see the poppet open since the engine temp would drop to the ambient surface of...
Sep 1, 2026
Texasmark
We each have our own idea as to how we maintain our equipment. I'm a "don't fix it if it ain't broke" guy especially on water pump...
Sep 1, 2026
Texasmark
Question about the 1990s era 75/80 and 90 lower unit swap to 100/115 and 125hp
That's true....the 90 had a 2.33 and the 115 2.0 lower unit gear ratio.
Sep 1, 2026
newtoboat101
1988 THOMPSON 240 FISHERMAN REBUILD
thanx for your help ,but AI is gonna help rebuild my boat ,i use ai for all the info i need ,and it a great helper for any fiberglass...
Sep 1, 2026
P
Pmt133
Sep 1, 2026
P
Pmt133
reacted to
alldodge's post
in the thread
with
Like
Is a weird one but with lube coming out water intake holes I would look at the water pump housing
Sep 1, 2026
P
Pmt133
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... Or the shift shaft seal,....
Sep 1, 2026
