T
ttles714
replied to the thread
Yamaha T9.9 no power to starter
GENERAL STARTER CIRCUIT.. Test with volt meter or test light .. A Starter is controlled by A solenoid .. the control voltage side of...
Sep 2, 2026
P
Pmt133
Questions about the set up of a Holley 4160 on a 4.3 V6
I've seen replacement coils cause all sorts of weird running issues. What kind of coil did you use?
Sep 2, 2026
Ethanol!
I agree with you that the problem likely is not E10. We've been running E10 in Minnesota for eons and after all the non-ethanol fuel...
Sep 2, 2026
S
saltchuckmatt
8hp Johnson idles well, but stumbles under load, sometimes
As far as the idle circuit your guessing it's ok...but, that being said...it looks more electrical. Is the timer plate wobbly under the...
Sep 2, 2026
Lou C
Tried it again, and no dice. Runs like crap. One thing I did find out though when it was running really bad with the Quadrajet, I...
Sep 2, 2026
Lou C
Ethanol!
The issue is this: this is all being done for political and economic reasons adding ethanol to motor fuel raises octane but causes many...
Sep 2, 2026
redneck joe
Random
https://www.facebook.com/share/r/199dAQhA9R/
Sep 2, 2026
Big Gee
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
The bottom was done cheap, just spray it and walk away. The color looked decent on a spot that I sanded and buffed. Just waitint on the...
Sep 2, 2026
K
kenny nunez
Gen 4 454 harmonic balancer screaming?
Does the noise happen with the belts off? If not then you may not have the power steering or sea water pump mounted out of alinement...
Sep 2, 2026
M
MikeSchinlaub
reacted to
Ifishmuskie2's post
in the thread
Thank you for the help, boat is ready.
with
Like
Thank you for the help getting my boat ready. I figure about 300hrs of repairs and upgrades. This forum helped with some answers...
Sep 2, 2026
A
ArtVandaley
Behold!
Sep 2, 2026
reacted to
Ifishmuskie2's post
in the thread
with
Like
Sep 2, 2026
A
ArtVandaley
Hey saltchuckmatt! I unscrewed the slow speed needle (15) and shot a bunch of carb cleaner through it. I did eyeball the main jet/high...
Sep 2, 2026
A
airshot
Not worth the gamble when I know the oem stuff always works.
Sep 2, 2026
stupid question - trailer lights
You pic shows a 5 wire plug which is made for surge disc brakes and would use solenoid so the trailer could be backed up. You want a 4...
Sep 2, 2026
