IslandExplorer
replied to the thread
1978 Islander 22 I/O
Well, it sure isn't looking like your first try at it, coming out great! That little area is a real focal point when you first enter the...
Sep 4, 2026
K
Kissdude
80 HP Mercury trim
My bad! I went and put a 30 Amp fuse on my power wire when I upgraded my wiring, these pumps have a built in fuse so now I assume I...
Sep 4, 2026
IslandExplorer
reacted to
66Holiday924's post
in the thread
with
Like
This boat is my first attempt ever at doing boat interior.
Sep 4, 2026
Berdink
Beautiful Johnson Survivor
I was thinking similar. I've been looking closely at that there on other motors like mine because mine had a whole lot less thread...
Sep 4, 2026
Berdink
reacted to
tphoyt's post
in the thread
with
Like
Likely a marking paint / goop so one can tell if the linkage has been molested.
Sep 4, 2026
D
damo79
Alignment Tool for Aplha One Gen 2
Found also this checking transom drawing. Not sure but seems that its either u-shape type like I have or normal washer no. 7 Still need...
Sep 4, 2026
dwco5051
reacted to
The nut's post
in the thread
Need help! Mind of its own Johnson gt150😬
with
Like
I deleted the vro and run mixed in tank And I believe the alarm works as it makes a short chirp every time I turn key on
Sep 4, 2026
WIMUSKY
iboats Football Pick 'em is back!
It's just for bragging rights ...
Sep 4, 2026
WIMUSKY
reacted to
FLATHEAD's post
in the thread
with
Like
No money involved, it’s just a fun thing.
Sep 4, 2026
C
Capt dave 258
Tilt/trim problem
I'm filling the pump via the top hole, replacing the screw and running the switch up and down with no motor movement. When I remove the...
Sep 4, 2026
WIMUSKY
Last weekend at the lake
Hope to get a couple more cruises in this month. Then have it winterized at the end of the month. Too much going on to bother with it...
Sep 4, 2026
A
airshot
stupid question - trailer lights
Until it doesn't....
Sep 4, 2026
D
DeepCMark58A
reacted to
garbageguy's post
in the thread
with
Like
No pontoonicus (of ours) at our dock at Big Moose Lake, yet. Going up Tuesday, probably only a couple more cruises this season in the...
Sep 4, 2026
B
boscoe99
Upgraded from 2 stroke to 4 stroke Yamaha, need guages
Sep 4, 2026
B
boscoe99
Sep 4, 2026
