B
bakerjw
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Heading down to the river tomorrow to let it run in the water without muffs for a bit and let it really run to get hot and clean up and...
Sep 5, 2026
Lou C
replied to the thread
Mercruiser intermittent electrical / no start / no dash power
No power to the helm gauges and ignition switch with battery voltage OK suggests a fault in that engine's ignition wiring circuit, could...
Sep 5, 2026
dingbat
trailer spindle nut
It’s quite possible the races is not seated. From the procedure below: Use a torque wrench to tighten the adjusting nut to 50 ft...
Sep 5, 2026
B
Baba1
The problem on this boat is there is no access to the starter without removing the exhaust riser/elbow so I am doing what I can before...
Sep 5, 2026
J
jws123
Mercruiser 454 I Need Help Identifying This Engine
Evidently 454 marine engines are suddenly hard to get and 10x over priced for whatever reason right now. People want 5k for a used...
Sep 5, 2026
redneck joe
Random
Sep 5, 2026
C
80 HP Mercury trim
Trim limit switches are nice to have, but most boats do not need them, as the prop will ventilate, before the trim gets to it's limit...
Sep 5, 2026
C
trailer spindle nut
If you cannot take the play out of the bearing, without tightening it enough to bind, the bearing is bad and should be replaced. After...
Sep 5, 2026
C
Capt dave 258
Tilt/trim problem
The pump is leaking from the seal around the ram piston. I'm going to order a rebuild kit and address the leak. Thanks for your input...
Sep 5, 2026
aspeck
Boats from work.
A staycation or going somewhere fun?
Sep 5, 2026
bajaman123
trailer spindle nut
Scott nailed it. Some just tighten the nut, spinning the wheel until resistance is felt, then backing off one hole. The point is to...
Sep 5, 2026
bajaman123
reacted to
Scott Danforth's post
in the thread
trailer spindle nut
with
Like
Tighten to 20 ft-lb while spinning the hub, then back off to nearest hole
Sep 5, 2026
bajaman123
RV build quality - Rant
You have to understand that after 2020 build years, these things were built on a piece-rate basis...with the accompanying poor quality...
Sep 5, 2026
reacted to
in the thread
with
Like
RVs are priced like boats, but build quality is 40 years behind the times. Will post some pics as I pull things apart. Poor design and...
Sep 5, 2026
Sep 5, 2026
