A
airshot
reacted to
bajaman123's post
in the thread
RV build quality - Rant
with
Like
You have to understand that after 2020 build years, these things were built on a piece-rate basis...with the accompanying poor quality...
Sep 5, 2026
A
airshot
reacted to
tpenfield's post
in the thread
with
Like
You have too many hobbies . . . RV's are just boats that don't float. :ROFLMAO:
Sep 5, 2026
Bt Doctur
replied to the thread
cool fuel III interesting trouble
Jut got a second one from the scrap heap. fully functional, good fuel pressures .clean fuel filter and mesh screen,unit cost $1600...
Sep 5, 2026
A
airshot
Lowrance LCX-15 power cord
What about contacting Lawrence themselves ?
Sep 5, 2026
A
airshot
Servicing my trailer bearings
I would recomend leaving the bottom if the bunk ooen, meaning no carpet on the wood on the bottom side if the bunk. I have found the...
Sep 5, 2026
Bt Doctur
posted the thread
blue plug ear breakage
in
Boat Topics and Questions (not engine topics)
SS replacements available from Hardin Marine Just got mine and there remarkable. Something I should have developed,
Sep 5, 2026
A
airshot
reacted to
flashback's post
in the thread
with
Like
If your gonna do one then do them all. It's a messy job. One time and done.
Sep 5, 2026
A
airshot
reacted to
Captain Caveman's post
in the thread
with
Like
When dealing with a lot of grease, I use those cheap, disposable nitrile gloves. For packing, I put grease into the palm of the glove...
Sep 5, 2026
A
airshot
reacted to
alldodge's post
in the thread
with
Like
Many times the heat coming from the bearings is actually coming from the brakes. Might need to replace the brakes, or any of it's parts...
Sep 5, 2026
reacted to
Lou C's post
in the thread
Mercruiser intermittent electrical / no start / no dash power
with
Like
No power to the helm gauges and ignition switch with battery voltage OK suggests a fault in that engine's ignition wiring circuit, could...
Sep 5, 2026
A
airshot
Beautiful Johnson Survivor
If the motor is as nice as the ad states it might be a decent buy especially due to the tiller and power trim. If you need that type of...
Sep 5, 2026
P
Pmt133
The 15-20 year old ones are just as bad. They've always been crap.
Sep 5, 2026
Lou C
2001 Volvo Penta 5.0 GL cracked block
You also have to pull off the bottom of the big hose between the 'stat housing and the front circulating pump, did you do that? GM...
Sep 5, 2026
L
Laneman25
Well I've watched a few videos and several boat owners had long term success with JB weld. If anyone here has tried it please add some tips.
Sep 5, 2026
C
Gee, sorry that happened. Water is tricky and can get trapped in areas of the block. I always filled my block with straight automotive...
Sep 5, 2026
