R
Robobrainiac
reacted to
Lou C's post
in the thread
OMC 4.3 Electronic Ignition Swap
with
Like
Fuel pump pressure, volume and vacuum Anti siphon valve & fuel pick up tube. All should be checked
Sep 7, 2026
rickasbury
replied to the thread
Servicing my trailer bearings
Nylon nuts? I assume for corrosion and there is no pull on them but nylon?
Sep 7, 2026
E
eathen13
1987 evinrude 140hp E140tlcua
Sep 7, 2026
jimmbo
New Stuff on Vehicles likes/dislikes
An Update. 3yrs later, the Disabler still works fine, but it does cause the charging system to refuse to fully charge the battery. My...
Sep 7, 2026
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I think @nola mike asked about fuel usages vs speed, etc. Now that I have run the boat for a longer period of time, I was able to put...
Sep 7, 2026
jimmbo
reacted to
Sprig's post
in the thread
with
Like
I absolutely hate the auto stop/start feature that turns off the engine when I stop and then turns it on when you step on the...
Sep 7, 2026
N
nrobst
Air-conditioning
Hi @ericcarr - what polar Bay A/C did you install please? I’m investigating putting A/C in my 2003 Maxum 2500SE Thanks! Neil
Sep 7, 2026
tpenfield
Boat purchase
Well, no survey is ever 'clean' . . . it is just a matter of the items called out being manageable /acceptable.
Sep 7, 2026
K
kyle_r
Newbie trying to fix up a (possible) StarCraft Nova 16
I wasn't able to see another serial number under the cowl. just the one sticker on the underside of the motor. I'm going to try and get...
Sep 7, 2026
Lou C
Sep 7, 2026
K
kyle_r
I forgot about that part, I'll need to figure that out. Wish I has a little more solid idea of which year the boat is.
Sep 7, 2026
J
Jeff J
Personally, I would not fill the hub if there is no zerk fitting. I don’t use the zerk fitting even if there is one. I do spread some...
Sep 7, 2026
P
Pmt133
Alpha One Gen 2 Outdrive Mystery
I feel it is easier to split and reassemble the halves off the boat with the lower in a stand... but it's personal preference really...
Sep 7, 2026
M
Mark R.
I'm hoping to get some time this week to try to address this problem. I am pretty confident of my recent reseal of the upper outdrive...
Sep 7, 2026
rickasbury
I recall some pitting on the spindles but more in between the bearings as I recall. The spindles i believe were welded on ...whatever is...
Sep 7, 2026
