J
jase34242
posted the thread
Found a destroyed raw water impeller today.. where to start looking for the pieces?
in
Mercury MerCruiser Sterndrives & Engines
Well this isnt what I wanted to find in my 383 freshwater cooled (full closed loop) motor today.. I found one piece right in the back...
Sep 7, 2026
Berdink
replied to the thread
1978 Mercury 70hp Worth Messing With?
Sep 7, 2026
roscoe
Newbie trying to fix up a (possible) StarCraft Nova 16
Capacity plate should be small metal plate nailed onto the inside of the transom. No hull ID on boats pre '72, just a serial number...
Sep 7, 2026
Berdink
posted the thread
in
Mercury & Mariner Outboards
Assuming it has good compression. Assuming it runs and has a good lower unit. Is it worth keeping? It looks like parts are a little hard...
Sep 7, 2026
Ayuh,..... Welcome Aboard,...... Cute little hull,.... You won't be needin' the fiber-glassing skills,... Aluminum hulls...
Sep 7, 2026
reacted to
redneck joe's post
in the thread
with
Like
a set of muff is like $20 bucks.
Sep 7, 2026
Servicing my trailer bearings
For the most part yes, than take your finger and dig out all the grease around the castle nut and put the seal back on. Your digging...
Sep 7, 2026
R
Have a 76 Johnson 85v4 will a 85 power trim& tilt fit
As per usual the seller just does not know what fits what.----That unit was NEVER offered on a 200 HP and only fits the 2 cylinder...
Sep 7, 2026
M
mikebbbbb
Shift interrupt switch
So is the newer style shift plate available for my 1995 3.0?
Sep 7, 2026
rickasbury
Ok, so I'm re thinking what little I know about these bearing systems. I just watched a you tube from Rockwell showing how their system...
Sep 7, 2026
B
bakerjw
Looks like a cool boat. Should make for some great memories.
Sep 7, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
with
Like
the 60 was made from 1960 thru 1990, none start with a 0, the 90 starts with a C and the number convention of 6 digits after that fits...
Sep 7, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
with
Like
Sep 7, 2026
B
bakerjw
reacted to
kyle_r's post
in the thread
with
Like
I recently purchased an "as-is" boat from an old neighbour. My oldest daughter (23) is very interested in boating and fixing one up with...
Sep 7, 2026
B
bakerjw
reacted to
eggs712's post
in the thread
1985 Bayliner 2750 Ciera Sunbridge Resto
with
Like
The new motor is dropped in successfully, just have to hook everything up now.
Sep 7, 2026
