Berdink
reacted to
Mc Tool's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
Well , if it has all the things you assume it has , wtf not , I mean it looks to be in reasonable nick . If it goes ok and doesnt have...
Sep 8, 2026
Berdink
replied to the thread
Yes, all the fuel lines need replacing. I won't even attempt to turn it over without replacing all of them - they are dried stiff. And...
Sep 8, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
OMC 4.3 Electronic Ignition Swap
with
Like
Yes
Sep 8, 2026
C
Crosbyman
Tilt/trim problem
cycle and refill a few times to purge any air .......unlikely you had 2 problems...seals and motor at the same time.
Sep 8, 2026
K
kenny nunez
Found a destroyed raw water impeller today.. where to start looking for the pieces?
When I had the Donzi I found some pieces in the check valve. It was raw water cooled and the check valve was located just below the...
Sep 8, 2026
Lou C
2001 Volvo Penta 5.0 GL cracked block
Agreed, the suck it up via the outdrive method does not work because of the nature of raw water cooling. With a cold engine, the stat is...
Sep 8, 2026
Texasmark
Follow the fuel input hose to the fuel pump attachment point.....look at the hose below it.....I see what looks like that connection is...
Sep 8, 2026
R
200 venom idle and runability
Spark maximum advance is set for life of the motor.----Normally needs no adjustment.----Make sure it is correct.
Sep 8, 2026
C
Capt dave 258
Tilt/trim problem
Replaced the seals and it's no longer leaking. I believe the pump is full of fluid and bled. The motor only goes up with me pulling up...
Sep 8, 2026
dingbat
Have you checked the location of the timing pointer per the manual? Done a complete link and sync?
Sep 8, 2026
R
Not a robust lower unit for a 70 HP.----And 2 carburetors for 3 cylinders.----Not on my list of favorite motors.
Sep 8, 2026
D
DeepCMark58A
Happy Labor Day !!!
I put the ski boat in storage today, put all the skis and tubes and life jackets in the boat have it pretty packed. Got home and...
Sep 8, 2026
R
Evinrude E90ELEUC RPM issue while running.
Should be 6 numbers for a part #
Sep 8, 2026
C
Cameron119
Here are the numbers off the prop
Sep 8, 2026
rickasbury
Servicing my trailer bearings
I know there is a seal in the rear but I don't think there is one in the front?
Sep 8, 2026
