rickasbury
reacted to
airshot's post
in the thread
Servicing my trailer bearings
with
Like
Sorry for the spell checker mistake....I meant NYLOK nuts, A metal nut with a nylon insert to keep it from vibrating loose.
Sep 8, 2026
R
replied to the thread
200 venom idle and runability
Checked the flywheel key??
Sep 8, 2026
J
Jeff J
reacted to
Crosbyman's post
in the thread
Tilt/trim problem
with
Like
cycle and refill a few times to purge any air .......unlikely you had 2 problems...seals and motor at the same time.
Sep 8, 2026
J
Jeff J
The dust cap or bearing buddy provides the seal on the front. That’s why those rubber pieces need replaced on the caps used with axles...
Sep 8, 2026
Berdink
1978 Mercury 70hp Worth Messing With?
Thanks, I'll look further into it this winter. I need to get back to more pressing projects. I mainly wanted to verify the motor had...
Sep 8, 2026
M
muc
Alpha One Gen 2 Outdrive Mystery
30 year old boat has probably had more then a few changes. TB4 is fine, hope you have replaced that 3M scotch lock --- they BAD on...
Sep 8, 2026
Berdink
reacted to
Chris1956's post
in the thread
with
Like
I assume you tested for power at the #2 coil primary? A standard voltmeter may not show the quick pulse that fires the coil. You might...
Sep 8, 2026
C
Sep 8, 2026
Berdink
Some stinky old fuel in the carbs. And the hoses look original. I'll need to clean up some corroded wiring and clean the carbs, and run...
Sep 8, 2026
redneck joe
reacted to
Berdink's post
in the thread
with
Like
139, 137, 135. Spark jumps a 1/2 inch gap on 1 & 3. No spark on #2. No spark even at coil of #2. . Really funky build for getting to the...
Sep 8, 2026
Berdink
Sep 8, 2026
Big Gee
reacted to
john from md's post
in the thread
If you have high charge voltage, please read
with
Like
Re: If you have high charge voltage, please read Will the moderator please delete the posts relating to the bickering between a couple...
Sep 8, 2026
M
muc
Yes 8M0214948 Seal Carrier It will include the 8M0142854 O-ring and one 864319 double lip seal. If you're doing an impeller job...
Sep 8, 2026
N
Nordin
Need help identifying motor , 5hp 2 stroke mercury
That is a 1985-86 year model and as racerone marketed as Mercury and also marketed as Tohatsu. Here in Europe it also was rated as 4Hp...
Sep 8, 2026
P
Pmt133
Swim Platform Slap - Reduce?
Does it just sit low or is it sitting low because it is water logged. I only ask because at that age and being new to you there can be...
Sep 8, 2026
