Happygolucky
reacted to
jimmbo's post
in the thread
Mercruiser 5.7 wanting to stall at idle after driving around
with
Like
I can hear the Stones. I see a Zinc Carb, and I want it painted Black
Sep 9, 2026
jimmbo
replied to the thread
Convert trailer for inboard use
What's the Problem with the current Trailer, that you want to replace it?
Sep 9, 2026
jimmbo
1978 Mercury 70hp Worth Messing With?
Hopefully you have a Factory Service Manual. If not get one, as it will have the correct procedure for the Link and Sync, as well as...
Sep 9, 2026
jimmbo
Boat doesn't rise. Prop issue?
WOT range for that motor is 4500-5500. While the motor is rated 140hp at 5000rpm, the actual rpm for peak power on the 140 is closer to...
Sep 9, 2026
jimmbo
reacted to
racerone's post
in the thread
with
Like
Not a robust lower unit for a 70 HP.----And 2 carburetors for 3 cylinders.----Not on my list of favorite motors.
Sep 9, 2026
redneck joe
you shoulda bought the flux model....
Sep 9, 2026
bowler
reacted to
Scott Danforth's post
in the thread
Swim Platform Slap - Reduce?
with
Like
Add more beer to the cooler in the bow. It will tilt the boat a bit bow forward, and after a few..... You won't care Agree with above...
Sep 9, 2026
bowler
reacted to
Chris1956's post
in the thread
with
Like
I live on the Bay. Water slapping can be soothing, after you get used to it.
Sep 9, 2026
B
Bman2895
posted the thread
in
Prop Questions and Topics
So info. Boat is a 1990 Cajun paul Elias edition. 18' 6" long × 88" beam. Everything i find shows its a 1,200 lb bare boat. The boat...
Sep 8, 2026
SHSU
Original 1967 Styrofoam?
Looks like the original foam I pulled out of my SS16 SHSU
Sep 8, 2026
SHSU
'67 Holiday 18' - Make it Usable
Looks like the foam I pulled out of my 1986 SS16 SHSU
Sep 8, 2026
SHSU
reacted to
IslandExplorer's post
in the thread
1974 Chieftain 25 "Adventurer" Restoration
with
Like
Sep 8, 2026
B
Bman2895
Unrealistic expectations for 71 20hp johnson?
So just an update. The motor was never quite getting full throttle. The bracket responsible for holding the throttle linkages and by...
Sep 8, 2026
R
Robobrainiac
OMC 4.3 Electronic Ignition Swap
Yes, I have the quadrajet. We had 3 years of trouble free use since I bought it. I put an impeller in it and battery and have had no...
Sep 8, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
with
Like
Here's what it looks like when you have it apart it is a bit tricky to get the air horn off and the choke linkage on the side properly...
Sep 8, 2026
