redneck joe
replied to the thread
daily music fix
https://www.facebook.com/share/r/1998Bdrsz5/
Sep 9, 2026
T
tphoyt
reacted to
saltchuckmatt's post
in the thread
Outboard gas tank problem
with
Like
Lots of aftermarket Evinrude fuel ends that don't quite work. Get an OEM one. Don't run the motor anymore until fuel lines, carb and...
Sep 9, 2026
A
airshot
Servicing my trailer bearings
Yes....if the prior grease is unkown, better to clean out everything and use a known grease to rebuild. Some types of grease do not mix...
Sep 9, 2026
A
airshot
Lowrance LCX-15 power cord
Minn Kota stopped supporting there old stuff as well....but they did send me to an aftermarket company that could supply everything I...
Sep 9, 2026
A
airshot
reacted to
in the thread
with
Like
Sep 9, 2026
C
Boat doesn't rise. Prop issue?
You want to trim up until the prop ventilates and then down a bit until she bites the water. A lot of motors will only trim up a...
Sep 9, 2026
sangerwaker
reacted to
Scott Danforth's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
2-stroke and race gas make me horny I even have candles on my wish list. But the wife says no
Sep 9, 2026
S
saltchuckmatt
Sep 9, 2026
S
saltchuckmatt
Unrealistic expectations for 71 20hp johnson?
Excellent...time to go use it.
Sep 9, 2026
S
saltchuckmatt
1987 evinrude 140hp E140tlcua
To me, your not running on all cylinders.
Sep 9, 2026
Berdink
1978 Mercury 70hp Worth Messing With?
Yeah, but it needs 1.21 gigawatts to work.
Sep 9, 2026
Berdink
reacted to
jimmbo's post
in the thread
with
Like
Hopefully you have a Factory Service Manual. If not get one, as it will have the correct procedure for the Link and Sync, as well as...
Sep 9, 2026
Berdink
Yes, I took lots of pictures as I removed things. It screwed into the bottom of the cover that was over the carbs.
Sep 9, 2026
Texasmark
reacted to
jimmbo's post
in the thread
with
Like
WOT range for that motor is 4500-5500. While the motor is rated 140hp at 5000rpm, the actual rpm for peak power on the 140 is closer to...
Sep 9, 2026
R
What bore size is marked on the " smaller " 1983 carburetors?
Sep 9, 2026
