T
tphoyt
reacted to
WIMUSKY's post
in the thread
Random
with
Like
https://www.facebook.com/share/r/1Fgj8KrmHs/
Sep 9, 2026
Berdink
reacted to
Rstacy's post
in the thread
Suggestions for a 1978 TOP 900 coil
with
Like
So kind of strange but here it is. I bought an aftermarket coil and it would barely run. I installed the old coil and it started right...
Sep 9, 2026
Berdink
reacted to
jimmbo's post
in the thread
with
Like
Can the spark jump a 7/16" gap? On every plug wire? Are the carbs dribbling gas out of the vents when running? Are they all fully closed...
Sep 9, 2026
Berdink
reacted to
Chris1956's post
in the thread
1977 1150 Coil Replacement Options
with
Like
Sierra should make a coil for your motor. You need to look a bit more. Are you sure the coil is bad? They last a real long time....
Sep 9, 2026
M
MikeSchinlaub
replied to the thread
Random
12. Non-Genuine Forum Participants, such as Bots, sock-puppets, imposters, and the like will be removed from the forums as they are...
Sep 9, 2026
W
wellcraftJoe
Replaced engine now no spark
Yes I've read the sticky, it was very useful I have actually just sat down for the day from work and am trying to find wiring...
Sep 9, 2026
WIMUSKY
Random
Sep 9, 2026
Berdink
reacted to
Laddies's post
in the thread
Merc 9.8 coil
with
Like
Re: Merc 9.8 coil The right part number for the replacement part is 339-5288T2. When in doubt on part numbers goto BAM Marine.com
Sep 9, 2026
M
MikeSchinlaub
reacted to
flashback's post
in the thread
How do i get this out?
with
Like
Wet sand it with 800- 1000 grit sandpaper and then buff with a good buffing compound.
Sep 9, 2026
Berdink
1978 Mercury 70hp Worth Messing With?
Yeah, my research is telling me this same lower unit is used all the way down to a 30hp. And the 70hp was the biggest motor they used...
Sep 9, 2026
flashback
Sep 9, 2026
Lou C
Is it true that Easy Load roller trailers ruin fiberglass boats???
I would say use whatever the manufacturer advises. I have had a roller trailer under my boat for many years with no damage. In my...
Sep 9, 2026
Berdink
Original 1967 Styrofoam?
Yeah, I keep my boat out of the weather. The floor is sturdy and dry. Surprisingly, (knock on aluminum) I haven't found any leaking...
Sep 9, 2026
G
gman546
posted the thread
in
Boat Topics and Questions (not engine topics)
No matter what i do i cant get these what look like to be either spider poop or bird poop marks out of my gel coat. i sit there with...
Sep 9, 2026
Berdink
reacted to
SHSU's post
in the thread
with
Like
Looks like the original foam I pulled out of my SS16 SHSU
Sep 9, 2026
