99yam40
replied to the thread
No tach,no charging
was the motor running? maybe disconnect the yellow wires from the RR and try it again to see if you get anything from that coil
Sep 11, 2026
tpenfield
Where were you 25 years ago today.
In the days after 9/11 I remember being outside and how eerie quiet it was. Then I realized how accustomed 'we' had become to jets...
Sep 11, 2026
ezbtr
Right before leaving for work, arriving, getting as much live streaming possible, (no TV) , ended up there a few weeks later, MAJOR...
Sep 11, 2026
ezbtr
reacted to
flashback's post
in the thread
K&N air filters......yay or nay ?
with
Like
Those things got popular when we were putting glass packs on our old cars. Less restriction of exhaust and intake added a few ponys. It...
Sep 11, 2026
rickasbury
Servicing my trailer bearings
Got the boat home and got to work. I bought medium gloves- would not fit. First time any latex on my body needed anything larger than...
Sep 11, 2026
Ifishmuskie2
No tach,no charging
I just tested the two yellow wires on AC and got zero.
Sep 11, 2026
Ifishmuskie2
reacted to
99yam40's post
in the thread
No tach,no charging
with
Like
when reading the yellow wires did you have the meter set to AC since that is what is suppose to be on the yellow wires?
Sep 11, 2026
Ifishmuskie2
No tach,no charging
No I had it set to dc volts.
Sep 11, 2026
9
99yam40
No tach,no charging
Sep 11, 2026
Fun Times
cool fuel
Probably cheaper to have something made up professionally… Not seeing the-1 at the end but the number seems good still...
Sep 11, 2026
Ifishmuskie2
reacted to
Chris1956's post
in the thread
No tach,no charging
with
Like
You can also, disconnect the yellow wires and run the motor on a flusher and look for AC voltage on the two yellow wires. I would...
Sep 11, 2026
Ifishmuskie2
reacted to
Dukedog's post
in the thread
No tach,no charging
with
Like
tha one in your picture is a combination reg/rectifier.. is same as as most mercs of tha early ninties up to somewhere in tha 2000's...
Sep 11, 2026
Ifishmuskie2
reacted to
boscoe99's post
in the thread
No tach,no charging
with
Like
By serial number your model uses a voltage regulator. Which of course has a rectifier inside. Single phase AC output from the...
Sep 11, 2026
Ifishmuskie2
No tach,no charging
I checked stator output on the two yellow wires and got 12.3 volts. (That’s the battery voltage) That’s with everything hooked up and...
Sep 11, 2026
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Interesting, how exactly does leaving the tank connected cause that? I'm curious
Sep 11, 2026
