  • B
    boscoe99 replied to the thread No tach,no charging.
    You are seeing battery voltage on the stator output wires with those wires not connected to the regulator?
  • B
    It is a voltage regulator. Not just a rectifier.
  • Sprig
    Sprig reacted to tphoyt's post in the thread Big Thanks with Like Like.
    I just want to give a Big Thanks to all the mods. You’re all rock stars for donating your time to running this great forum. Thanks to all
  • Ifishmuskie2
    Ifishmuskie2 reacted to 99yam40's post in the thread No tach,no charging with Like Like.
    like Boscoe99 said the yellow wires need to be disconnected from the RR when testing for AC to see if it is putting any AC voltage
  • Ifishmuskie2
    Ifishmuskie2 replied to the thread No tach,no charging.
    With engine turned off I get battery voltage at the two yellow wires from the stator at the junction box near the coils.
  • alldodge
    alldodge replied to the thread Maybe my turn for new boat time.
    No, mine with cash from me Boat didn't have a trailer, so I pay them 49K
  • 9
    99yam40 replied to the thread No tach,no charging.
  • C
    Chris1956 replied to the thread No tach,no charging.
    That is normal behavior for the tach.
  • C
    The slave solenoid battery post is often used as a junction for all wires carrying a continuous +12VDC power. So if you have any wires...
  • Ifishmuskie2
    When I turn the key the tach moves to zero and the volt gauge moves the 12.5volts
  • Berdink
    Berdink reacted to Mc Tool's post in the thread 1978 Mercury 70hp Worth Messing With? with Like Like.
    yep . One of the things that makes a good mechanic ( or any repair man ) is the ability to diagnose the problem and one advantage a...
  • C
    There is no bench test for a voltage regulator that I know of. You could feed it 16VAC and see what it puts out. It should try to put...
  • tpenfield
    Yes, I was going to offer some guidance and technical assistance on that. :LOL: Probably twin 250 HP
  • tpenfield
    So, is the dealer taking your boat (Chap 280) and trading it for the Formula 270. . . . Like an even swap?
  • Lou C
    I was wondering about that too! I don't have the Ford 5.8 in my OMC shop manual (they weren't using it yet) but I do have the diagrams...
