Ifishmuskie2
replied to the thread
No tach,no charging
Yes that is correct.
Sep 12, 2026
S
SeaRayboater95
Milky oil
Port side was was kinda floppy and the other side was missing.
Sep 12, 2026
tpenfield
Maybe my turn for new boat time
Interesting find . . . a 2 yr old demo boat with barely break-in hours. :cool:
Sep 12, 2026
Yes has Cats and I don't like them either Think all since 2012 or 2014 something like that
Sep 12, 2026
Berdink
1978 Mercury 70hp Worth Messing With?
I'm learning. 😊
Sep 12, 2026
B
boscoe99
No tach,no charging
So on the red and black wires you are seeing battery voltage only when the motor is off but then no increase in voltage when the motor...
Sep 12, 2026
nola mike
Does it have cats? They scare me, though probably not as big a deal in the fresh.
Sep 12, 2026
nola mike
Milky oil
Was the oil level increased? Might try an oil change and run it on muffs for a while to see if it returns. You can pressure test the...
Sep 12, 2026
Depends on fresh or salt water, I'm in fresh so don't worry much about corrosion. Impeller is cheap enough, everything else is not like...
Sep 12, 2026
Ifishmuskie2
No tach,no charging
Yes 18v ac. With a probe on each yellow wire coming from stator. With engine running and two yellow wire disconnected from engine. So...
Sep 12, 2026
redneck joe
sorry, raw water parts attached to the motor. closed system of course is to prevent corrosion so wondering about this raw set up...
Sep 12, 2026
E
Ericavictoria
posted the thread
Remove the linkage to make throttle cam adjustment?
in
Johnson & Evinrude Outboards
Hello! Service manual says to carefully remove this. How do I go about that when I dont have the special tool? Best regards /Erica
Sep 12, 2026
Milky oil
Search for "gm oil pump primer tool" and several will show up Your motor may be fine, I'm just saying you need to get the water out if...
Sep 12, 2026
9
99yam40
No tach,no charging
well he wrote this also, but have no idea what the meter was set to. AC or DC "I just ran the engine with the two yellow wires coming...
Sep 12, 2026
yes, comes in goes back out warmer
Sep 12, 2026
