Ifishmuskie2
replied to the thread
No tach,no charging
The engine has a warning. When cowl off no more then 3000rpm. So I only had it at about 800 rpm when I checked the yellow wires from...
Sep 12, 2026
Ifishmuskie2
reacted to
Mc Tool's post
in the thread
No tach,no charging
with
Like
you should be getting 50+vac out of the stator at high revs and a bit below 20vac at idle .... Id say your stator is puckerood . This...
Sep 12, 2026
flashback
reacted to
alldodge's post
in the thread
Maybe my turn for new boat time
with
Like
Spring lake Michigan
Sep 12, 2026
Lou C
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Where's the Nitromethane one?! Ever since they quit having top fuel drag racing at Englishtown (Raceway Park) I am in nitro withdrawal.
Sep 12, 2026
T
tphoyt
Remove the linkage to make throttle cam adjustment?
Pry it off from the back. I have seen broken ones but I have never broken one. They are pretty tough. It’s just a ball and socket.
Sep 12, 2026
M
Mc Tool
1978 Mercury 70hp Worth Messing With?
:D I been at this lark 46 years and Im still learning
Sep 12, 2026
S
SeaRayboater95
Milky oil
Have a normal one on the bottom, back port side
Sep 12, 2026
Air Trapped in Outdrive...
Yes there is some air and how much depends on how the drive was refilled. On the boat, off the boat and angle. It also takes a little...
Sep 12, 2026
M
Mc Tool
No tach,no charging
Sep 12, 2026
Lou C
Milky oil
But the diameter of the non remote (standard) filter on the V6 is smaller than on the V8s, it all depends on what remote set up if any...
Sep 12, 2026
M
Mark R.
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
What happens with the pocket of air that gets trapped in the top of an outdrive.? We pump in the gear lube from below, and once full...
Sep 12, 2026
rickasbury
reacted to
jlh3rd's post
in the thread
Servicing my trailer bearings
with
Like
standard practice for castle nut adjustment is to snug the castle nut up as you rotate the wheel. You are setting the bearings, not...
Sep 12, 2026
reacted to
alldodge's post
in the thread
Milky oil
with
Like
Remote non-remote, filter will be the same thread
Sep 12, 2026
Milky oil
Sep 12, 2026
nola mike
Milky oil
Unless you have a remote filter
Sep 12, 2026
