J
jlh3rd
reacted to
Jeff J's post
in the thread
K&N air filters......yay or nay ?
with
Like
Yep, a person must follow the instructions if they want a shot at stuff working anywhere near what is advertised. Cleaning and oiling a...
Sep 13, 2026
Lou C
replied to the thread
Milky oil
You really need a pressure gauge to accurately measure if the water passages hold pressure. A fuel pressure gauge will work.
Sep 13, 2026
Lou C
reacted to
Bt Doctur's post
in the thread
starter concern
with
Like
if the starter tries to turn the motor over but groans it indicates fluid in the cylinders. It it turns briskly then burns up you have a...
Sep 13, 2026
Lou C
Replacing Risers/Elbows and Exhaust Manifolds on a Ford/OMC Cobra 5.8 Ltr
If you got Barr manifolds get Barr elbows. Can’t mix ‘n match brands. Better off just getting a whole Barr kit if they make it for your...
Sep 13, 2026
FLATHEAD
reacted to
Pmt133's post
in the thread
Just thought I'd share a nice photo.
with
Like
Old man looks happy. This is a little more flat out. First time I've seen the thing finished running around. Now I understand why...
Sep 13, 2026
M
Mc Tool
starter concern
How many batteries do you have .....just that it sounds like you might be getting 24v at the starter .........that would fry them pretty...
Sep 13, 2026
M
Mc Tool
No tach,no charging
google up a PDF , probly the easiest way :)
Sep 13, 2026
S
SeaRayboater95
Milky oil
Ok, I've done a bit of exploring since we last talked. I've drained the oil and filter will screen the first oil change. Forgot to clean...
Sep 13, 2026
P
Pmt133
reacted to
WIMUSKY's post
in the thread
with
Like
Duluth Lift Bridge Raised for sailboats, ore carriers etc...
Sep 13, 2026
P
Pmt133
Sep 13, 2026
K
KM7
New problem. The bolt holes in the exhaust manifolds do not line up with the bolt holes on the risers! I will return the aftermarket...
Sep 13, 2026
Maybe my turn for new boat time
Yes...catalytic converters
Sep 13, 2026
K
KM7
I was wrong. The hoses for the water come into the manifolds at the ends, just like on the original. Both ends have threaded holes to...
Sep 13, 2026
K
KM7
Checking the Wiring of the Assist Solenoid
Yes, the starter is not the original and has 2 wires, the larger one similar to a battery cable and a smaller red one going to the...
Sep 13, 2026
Correct, When docking I move the legs out about 15*
Sep 13, 2026
