  • E
    eathen13 replied to the thread 1987 evinrude 140hp E140tlcua.
    Motor does drop rpm from to much fuel when engaging choke
  • M
    I thought that the oil should be fairly evenly soaked into the filter ....like it wicks itself all over , and gotta admit I have...
  • redneck joe
    redneck joe replied to the thread starter concern.
    welcome to the forum
  • S
    SeaRayboater95 reacted to alldodge's post in the thread Milky oil with Like Like.
    Your doing good Pressurize to 15 psi to where it will hold and maintain. If it holds and then good
  • S
    SeaRayboater95 replied to the thread Milky oil.
    Ok. I guess I'll cut that hose off and pressure test from there. Looks like it rubbed through on the water pump belt. The previous owner...
  • P
    Pmt133 replied to the thread K&N air filters......yay or nay ?.
    They actually replaced mine a few times. Apparently they have a tendency to shrivel up in some applications. Mine shrank to the point...
  • alldodge
    alldodge replied to the thread Milky oil.
  • S
    Yes, in fresh water. I dont think they have ever been off. Customer has doe zero maintenance since he has owned the boat. I replaced all...
  • S
    Signon replied to the thread V6 240 impeller issue..
    Yes the splines have moved within the impeller. It lines up exactly with the mark in the end cover. That is the penta one so I assume it...
  • Lou C
    Lou C replied to the thread Milky oil.
    You’re in fresh water I’m thinking right? Has the exhaust ever been worked on?
  • S
    Maybe I'll cut that hose off above the hole and test again. I hope I can still get that hose. It needs to be replaced anyway. I didn't...
  • J
    jlh3rd replied to the thread K&N air filters......yay or nay ?.
    It's an ok filter, it's just that people over oiled it or oiled the wrong side and then blamed it when the MAF failed. And if you...
  • S
    I had a proper radiator test kit with a hand pump. Pump it up to 10lbs and I could see really small bubbles coming from under the tape...
  • M
    Mark R. replied to the thread Air Trapped in Outdrive....
    ^ Does that mean you don't remove the upper vent plug during the fill.? That seems like it would certainly simplify the whole process... .
  • J
    jlh3rd reacted to Jeff J's post in the thread K&N air filters......yay or nay ? with Like Like.
    Yep, a person must follow the instructions if they want a shot at stuff working anywhere near what is advertised. Cleaning and oiling a...
