M
Mc Tool
replied to the thread
Wisconsin Deer Hunting at Risk.
ruined it for themselves .... and probly lots of others . The inspector may well be an officious power crazy little chit but talk...
Sep 13, 2026
N
Nordin
Water pipe acess 1974 55hp 557HG
You have to pull the power head off to access the water tube seal.
Sep 13, 2026
N
Nordin
15hp gamefisher wiring diagram? model 225.581508
You need to have the engine deeper in the bucket. The water pump impeller is not self priming, the impeller housing have to be under the...
Sep 13, 2026
J
Johnnyl30y
200 venom idle and runability
Factory key
Sep 13, 2026
J
Johnnyl30y
Factory key, but the damage was done to the keyway in the crankshaft. It has been holding all season, but is just a little "off"
Sep 13, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
RV build quality - Rant
with
Like
I really hate Forrest River RV right now The cheesy roof joists that all busted apart The cheesy reinforcement for a cabinet...
Sep 13, 2026
M
meser300
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
Did you mean the carb idle needle?
Sep 13, 2026
M
meser300
Which number you mean?
Sep 13, 2026
roscoe
And a Jon-E hand warmer
Sep 13, 2026
R
I do not see a picture of the tip of the slow speed needle !-----Look under EXHAUST HOUSING for the parts.
Sep 13, 2026
M
meser300
Photo-2. The gap is about 1" for slow and 0.5" for start
Sep 13, 2026
R
Picture of the tip of the slow speed mixture needle?
Sep 13, 2026
M
meser300
posted the thread
in
Johnson & Evinrude Outboards
Hi folks, I'm newbie in the Johnson motors and met the next problem: Working through a full rebuild on this motor — carb rebuilt, fuel...
Sep 13, 2026
N1265
'77 Holiday Transom
Do I need the ones for a 1" hole or 11/4 "
Sep 13, 2026
Sep 13, 2026
