replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
is the paint coming of the mounting brackets?
Sep 14, 2026
M
meser300
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
That is exactly the problem. When the handle is at the 'start' point, there is a 0.5" gap between the cam and the follower (see photo...
Sep 14, 2026
tg3690
reacted to
Nordin's post
in the thread
Water pipe acess 1974 55hp 557HG
with
Like
You have to pull the power head off to access the water tube seal.
Sep 14, 2026
M
meser300
The compression is around 80 on both cylinders. The spark plugs are brand new Champion J6C. The gap is about 0.30.
Sep 14, 2026
T
tphoyt
You will have some spare time on your hands now for fun things.
Sep 14, 2026
R
Repowering my old 16ft aluminum boat thinking of going 4 stroke but have a question
And most shops are reluctant to do major repairs on 4 strokes.
Sep 14, 2026
R
RV build quality - Rant
There are few standards set for sturdiness / quality of the structure.-----Most buyers only look at cosmetics and convenience items.
Sep 14, 2026
A
airshot
Buying a used 4 stroke could be a big gamble, the reason being is they are " very expensive to work on" where two strokes are pretty...
Sep 14, 2026
R
Rpm
5750 RPM is maximum
Sep 14, 2026
tpenfield
End of the season for me . . . . Trailer all set to go . . . The boat came on the bunks pretty much dead center. (y) . . Backing...
Sep 14, 2026
Lou C
They make it "look" good on the outside but the inside not so much. I also don't like the use of torsion axles on these vs a spring...
Sep 14, 2026
M
Mc Tool
What's the word on the street about current Mercury models?
Yep , I have a M18d Tohatsu .....great motor
Sep 14, 2026
Lou C
Milky oil
Well that's a gamble, I would though. If one falls down the Y pipe you'll wish you did.
Sep 14, 2026
Lou C
2001 Volvo Penta 5.0 GL cracked block
Exactly, the thermostat functions as a gate valve, and due to the fact that with an engine running at idle, it won't build enough heat...
Sep 14, 2026
rickasbury
Servicing my trailer bearings
I did clean out the master cylinder but I did not have time to pursue more cleaning- I can only keep my boat out front for 2 days at a...
Sep 14, 2026
