S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
Water in the oil is just a symptom there are a number of causes in fact Mercruiser published a nice article on how to troubleshoot water...
Sep 14, 2026
S
SeaRayboater95
replied to the thread
Milky oil
Will do. Got the first oil change done. In the middle of the second one. Will do one more, then pull the elbows. Thanks Ken
Sep 14, 2026
Scott06
Engine stalling when you give it too much throttle on take off
Is your ignition advancing properly? 3 different carbs and same issue I would look elsewhere. Vacuum leak is also good to rule out...
Sep 14, 2026
Scott06
Milky oil
Fore you pull the intake do the pressure test with the spark plugs out you may have a bad head gasket That is leaking into a combustion...
Sep 14, 2026
P
Pmt133
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Everything seems to be 100 hours last I checked. Typically the increased oil capacity is more to help with loading of the oil.... Most...
Sep 14, 2026
Berdink
'67 Holiday 18' - Make it Usable
Yeah, we go to a place in Astoria called Buoy 10. It's a blast of a fishing opportunity, but need at least 12 gallons a day if we want...
Sep 14, 2026
ezbtr
Favorite pistols? Here’s a few of mine, a few I haven’t shot yet, looking forward to the 44 magnum.
CZ 9 x 18
Sep 14, 2026
flashback
reacted to
tphoyt's post
in the thread
with
Like
Guessing it holds so much to help with cooling if running hard and long trips?
Sep 14, 2026
Berdink
reacted to
redneck joe's post
in the thread
with
Like
good deal. I popped a 12 under my center console sear and have plumbed to the bow where I can fit a 6 gal. I get about 3 mpg
Sep 14, 2026
ezbtr
Beretta 380 from 1971
Sep 14, 2026
T
tphoyt
Sep 14, 2026
ezbtr
posted the thread
in
Dockside Chat
Like my 9 mm, 45, 9 x 18 , 32s, etc. haven’t shot my 44 yet though
Sep 14, 2026
S
saltchuckmatt
8 hp E'rude 1990 ... bonehead move
To bad...awesome motors.
Sep 14, 2026
C
Crosbyman
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
disconnect clip #33 from the vertical post this allow mag to rotate fully...
Sep 14, 2026
S
saltchuckmatt
reacted to
racerone's post
in the thread
with
Like
Post results of a compression test.----Actual numbers.-----Or remove cylinder head and inspect cylinder walls.----Head gasket is cheap.
Sep 14, 2026
