M
MikeSchinlaub
replied to the thread
Starting engines with jump box & dead house batteries
In that Tige I did a little while ago, the panel to the batteries had a sticker that said to disconnect the batteries before charging or...
Sep 15, 2026
Scott06
Milky oil
if water is getting in the combustion chambers they will be steam cleaned while running plug will be washed clean as well.
Sep 15, 2026
G
gegenator150
Water Intrusion
Thank you Scott. I believe this has always been a fresh water boat. I've changed the oil since getting it running (this was several...
Sep 15, 2026
nola mike
Milky oil
Just to make sure it's actually coming through the carb and you're not hearing it leak somewhere else. Like Lou said, the intake runners...
Sep 15, 2026
reacted to
Chris1956's post
in the thread
Adding antifreeze
with
Like
You do not start the engine to circulate the antifreeze. You pull all the plugs, which is 4 or 6 on a V engine. Probe/poke the...
Sep 15, 2026
if the batteries sat for a long time in a discharged state, they may never take a charge. best is to pull them and put a charger on...
Sep 15, 2026
Water Intrusion
first, welcome aboard the pictures call in doubt how much of a stand-up guy the prior owner is the exhaust ports show that the exhaust...
Sep 15, 2026
G
gegenator150
posted the thread
Water Intrusion
in
Mercury MerCruiser Sterndrives & Engines
Greetings all, I recently bought a gem of a boat with only 192 hours on the Mercruiser 3.0 from the original owner. The engine runs...
Sep 15, 2026
L
Lithrael
posted the thread
Starcraft Holiday windshield advice?
in
Starcraft Boats
Hi guys, I've got a white/yellow Starcraft Holiday, I think it's a 1973 on the grounds that I don't see a 15' Holiday in the 1974...
Sep 15, 2026
B
boscoe99
The mechanic does not understand basic electricity. Sounds like he is regurgitating something he read on the internet. The world has...
Sep 15, 2026
reacted to
Bt Doctur's post
in the thread
Adding antifreeze
with
Like
How did you drain the system ? IF a single point system my guess the engine block did not drain completely. You can verify by unhooking...
Sep 15, 2026
aspeck
2026 NFL/CFB News and Nonsense
I didn't think it was legal to break the huddle with more than 11 guys. Hmmm...
Sep 15, 2026
S
SeaRayboater95
Milky oil
I don't understand what blocking off carb would show. I put 15lbs to the hose coming from the power steering cool to pressurize the...
Sep 15, 2026
G
gman546
The warning is valid, but the explanation is a bit off. The alternator isnt going to send dangerous amperage through the electronics...
Sep 15, 2026
deeman7777
posted the thread
in
Boat Topics and Questions (not engine topics)
Long story short, I overheard a well respected mechanic tell a group this info. Story: The boat had 2 dead batteries since it was in...
Sep 15, 2026
