E
ejnichol
reacted to
Scott Danforth's post
in the thread
RV build quality - Rant
with
Like
I get plumbing and electrical issues..... seriously, have you ever met an Amish plumber or electrician? However lack of sealing of roof...
Sep 15, 2026
E
ejnichol
replied to the thread
Hello from new member
HI
Sep 15, 2026
southkogs
Welcome aboard!
Sep 15, 2026
reginaldo
6hp Nissan 4 stroke with broken water tube
An old thread but have recently run into the same problem with the same engine. To answer the question of "how did it happen": When...
Sep 15, 2026
M
Mc Tool
8 hp E'rude 1990 ... bonehead move
yeah , quite a bit over 50 .
Sep 15, 2026
reginaldo
posted the thread
in
Dockside Chat
Hi all my name is Reginaldo I'm in western wa. I have a 27' sailboat with a 9.8 nissan 4stroke and a 6hp nissan 4stroke for a dinghy. I...
Sep 15, 2026
9
99yam40
Engine stalling when you give it too much throttle on take off
still needs to see what the timing is at, and a timing light will show what it is, and if it is advancing when it should
Sep 15, 2026
kbait
if compression #’s are adequate (over 50), run it. If it will idle down slow, you got lucky!
Sep 15, 2026
C
starter concern
That is very strange. Years ago, I had a big block Ford (429 CID). When she was hot, and you immediately tried to restart her, she...
Sep 15, 2026
M
Mrshaund79
1983 Starcraft Islander
Also, any advice as far as replacing flooring is welcome.
Sep 15, 2026
nola mike
reacted to
Scott06's post
in the thread
Milky oil
with
Like
if water is getting in the combustion chambers they will be steam cleaned while running plug will be washed clean as well.
Sep 15, 2026
R
Renken2000Classic
Saw "Proudly Overbuilt" on a business truck some time back, probably a new construction company or the like, don't remember. They were...
Sep 15, 2026
M
Mrshaund79
posted the thread
in
Boat Restoration, Building, and Hull Repair
So ever since i seen one for sale and missed out I have been looking for a good fixer upper, i found a 22ft Hull is in good shape...
Sep 15, 2026
A
airshot
Is it true that Easy Load roller trailers ruin fiberglass boats???
No matter which style trailer, you need to properly support the hull.. Thin cheap hulls need even more support. My 1983 Islanders has...
Sep 15, 2026
A
airshot
reacted to
tpenfield's post
in the thread
with
Like
Your question is really about roller trailers vs. bunk trailers. . . . not specific to EZ load . . . Bunk trailers distribute load...
Sep 15, 2026
