Lou C
replied to the thread
Milky oil
When I had my water in the oil problem, I figured out a way to run the engine on the water hose briefly to check for combustion gas...
Sep 16, 2026
G
gegenator150
Water Intrusion
I tried filling the manifold every which way, I cannot get water to run out the intake ports (I was hoping this would be the case, as it...
Sep 16, 2026
Lou C
Servicing my trailer bearings
The piston might be aluminum, if so, keep in mind you have dissimilar metals, and brake fluid absorbs water. I would replace it. I use...
Sep 16, 2026
dingbat
I was in the same situation with my Kodiak Calipers three years ago. If you count the cost of the rebuild kits along with your labor...
Sep 16, 2026
A
airshot
For an extra 100, why rebuild ? No warranty with a rebuild...
Sep 16, 2026
starter concern
pull all the plugs and crank it over last Monday. if you wait more than a week, you risk loosing the motor.
Sep 16, 2026
reginaldo
Hello from new member
Puget Sound mostly
Sep 16, 2026
C
starter concern
Gee, pull all the spark plugs and put a strap wrench around the crank pully and see if she will rotate smoothly.
Sep 16, 2026
JustJason
Help - Boat Accident and Insurance
Pretty much this. I am not an adjuster, but as a consultant, I recommend what is loss-related and what is fair pricing for adjusters...
Sep 16, 2026
rickasbury
So i can't get this piston un stuck. Its SS- it still corodes? I have it soaking in wd40 abd I have a small compressor- i need a fitting...
Sep 16, 2026
Lou C
starter concern
Anytime a marine engine gives problems with cranking the two things to check first are battery/terminals & spark plugs for water.
Sep 16, 2026
deeman7777
posted the thread
Hot Take: A boat wheeled and waxed in spring is no different by fall
in
Boat Topics and Questions (not engine topics)
Walking the boat yards in the spring with the boats on the hard, it's impressive to see the shine some of the hulls have after a nice...
Sep 16, 2026
deeman7777
reacted to
dingbat's post
in the thread
Starting engines with jump box & dead house batteries
with
Like
This warning has nothing to do with charging the battery, per se. It’s all about preventing voltage transients (spikes) that could...
Sep 16, 2026
L
Lithrael
Starcraft Holiday windshield advice?
Fantastic, thank you! Yes, we were able to retain all of the original hardware apart from the damage to about half the clips for the...
Sep 16, 2026
JonBoat55
reacted to
aspeck's post
in the thread
with
Like
I spent years in the car business and always found it best to start out trying to treat the insurance company and adjusters as friends...
Sep 16, 2026
