FLATHEAD
reacted to
WIMUSKY's post
in the thread
Trail Cam pix......
with
Like
1st 'yote on the cam....
Sep 18, 2026
replied to the thread
What's the word on the street about current Mercury models?
I found this while spelunking. https://www.linkedin.com/posts/mercurymarine-goboldly-share-7025847991693447168-IwuS/
Sep 18, 2026
reacted to
redneck joe's post
in the thread
Easy way to remove carpet from aluminum deck?
with
Like
the easiest way is to pay someone else to remove it. good luck, none of it will be easy.
Sep 18, 2026
Water Intrusion
It's almost never a head gasket You have to listen to where the pressure is escaping from. 3.0 liter blocks bust in one of two...
Sep 18, 2026
RV build quality - Rant
My friend's Rockwood Mini Lite that is not very old and has torsion axles...bent frame! I will never buy a trailer with a Lippert frame...
Sep 18, 2026
F
froggy1150
Restoring 1975 glasply 2300, bilge question...
My cuddy was the same there was a step down toward the cabin. I laid a pvc drain down against the keel starting at the point in the bow...
Sep 18, 2026
A
affa
Adding antifreeze
Ok, thanks
Sep 17, 2026
M
Mc Tool
Starting engines with jump box & dead house batteries
I can recommend a Victron Blue IP22 smart charger....should have bought one years ago . My only beef is that the bluetooth range aint...
Sep 17, 2026
M
Mc Tool
reacted to
jimmbo's post
in the thread
with
Like
Myself, I would use a newer Smart Charger, at about 8-10 amps, as these can sense when a Battery has sulfated from a long period of...
Sep 17, 2026
M
Mc Tool
Yeah I been quizzing AI about my quad flywheels and the trigger node differences in production years , and by transposing the question...
Sep 17, 2026
reginaldo
posted the thread
6hp Nissan 4 stroke powerhead gasket identification
in
Honda & Tohatsu/Nissan Outboards
In the attached pic is the part in the red square the power head gasket? Attached photo is from tohatsu.online if not does anyone know...
Sep 17, 2026
WIMUSKY
Trail Cam pix......
Sep 17, 2026
R
ryanagler
reacted to
Lou C's post
in the thread
2018 Mercury 40 EFI – rhythmic RPM surging at WOT after 5 minutes – video
with
Like
Another possible cause might be a clogged screen (if it has one) on the fuel tank pick up tube. Also look in the stickies, there is a...
Sep 17, 2026
R
ryanagler
I replaced everything fuel related up to where it enters the engine. Tomorrow a fuel pressure gauge comes it will be interesting to see...
Sep 17, 2026
jimmbo
Sep 17, 2026
