M
Mc Tool
replied to the thread
Starting engines with jump box & dead house batteries
The back voltage you refer to is called excitation and its that which the regulator manipulates to control output voltage . Some alts...
Sep 18, 2026
reacted to
Scott Danforth's post
in the thread
5.0 Merc Compression Readings
with
Like
If your motor truly has 210 psi cranking, it's a 13:1 drag racing motor Mercruiser manual states cranking psi is 150 per cylinder Is...
Sep 18, 2026
reacted to
in the thread
with
Like
Sep 18, 2026
4.3 Valve seals
Head has had work done prior. The valve guide on right is stock, on left has been cut and a different seal
Sep 18, 2026
Sep 18, 2026
4.3 Valve seals
Scott, reason to mention you is it looks like it has 2 different type seals and have not seen the multi seal ones
Sep 18, 2026
4.3 Valve seals
Felpro and Mahle both sell seals and gaskets every day, nearly everywhere If your motor has 8 intake manifold bolts, the motor is a...
Sep 18, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
4.3 Valve seals
with
Like
https://www.drivparts.com/part-details.html?brand_code=BCWV&part_number=SS%2072530&part_name=Engine%20Valve%20Stem%20Oil%20Seal%20Set...
Sep 18, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
4.3 Valve seals
with
Like
I can't imagine they are marine specific. The heads are just plain old Chevy V6 heads. Take the casting # off the head and go to a GM...
Sep 18, 2026
Grub54891
Trail Cam pix......
You just did!
Sep 18, 2026
Grub54891
Milky oil
Yes. They are the same as automotive seals.
Sep 18, 2026
Doesn't change my comment, motors that run on 87 octane do not have compression numbers that high. If motor was designed to run on 93...
Sep 18, 2026
Lou C
I don’t think so it’s just be careful with jumpstarts and keep in mind sobs boats only have a 55 amp alternator not like on the vehicles...
Sep 18, 2026
N
New At This
Seasoned mechanic did the plugs, wires compression check.
Sep 18, 2026
B
boscoe99
Is anyone suggesting that electrically powered devices be kept turned off to the maximum extent possible in order to help the alternator...
Sep 18, 2026
