L
Lithrael
replied to the thread
Starcraft Holiday windshield advice?
All right, so we ended up pulling all the clips out of the rails and setting them on the windshield in approximately the right spots...
Sep 19, 2026
FLATHEAD
Trail Cam pix......
I’m back and forth on that. In one area I hunt I’d probably take one out if I had the chance. I hate to take an animal I will not eat...
Sep 19, 2026
B
boscoe99
No tach,no charging
If not the applicable warning from the service manual can you provide the document number and page number?
Sep 19, 2026
K
Kissdude
posted the thread
1986 70 HP Mercury Outboard
in
Mercury & Mariner Outboards
I was wondering if someone could help me please! I have an older 70HP Mercury outboard serial number OA743766, I purchased this without...
Sep 19, 2026
2026 - Mercruiser Cool Fuel 2 Module replacement
Cool fuel module is mounted to bracket not the motor mount, it's just behind the mount. Remove plastic cover (push inward top and...
Sep 19, 2026
reacted to
flashback's post
in the thread
Crazy happening in My area,.....
with
Like
Nice to see something good for a change. Nature finds a way.
Sep 19, 2026
matt167
Repowering my old 16ft aluminum boat thinking of going 4 stroke but have a question
I did just that. Took off an old Johnson 40hp and rigged a brand new Suzuki 25hp. The actual difference is about 10hp less but it didn’t...
Sep 19, 2026
J
Jeff J
Wood stove install
I have been kicking around the idea of a waste oil stove for my shop. I found some plans online for converting a hot water heater...
Sep 19, 2026
Dukedog
No tach,no charging
a black coming from under tha "pudding" was a tell-tale sign it was a reproduction and/or a knock off...............
Sep 19, 2026
C
canadianboater86
I’ve seen a few 60hp 4 strokes going for 3-4k on facebook a good running late 80s to mid 90s 2stroke around here is easily 3k...
Sep 19, 2026
C
canadianboater86
yes i’m in ontario my old 76 johnson doesnt hsve power trim or tilt which i need because alot of our lakes are shallow and spending...
Sep 19, 2026
J
Jeff J
Help - Boat Accident and Insurance
Insure a brand new vehicle and the rates increase as the vehicle’s value decreases. They will not replace with new even if you have paid...
Sep 19, 2026
B
Bman2895
Charging and tach issue. Voltage rectifier upgrade to 35amp?
Ah well the tach is most important anyway. I would have figured the grey wire off the square one was tach? Seeing as it was grey. I...
Sep 19, 2026
J
Jeff J
Starting engines with jump box & dead house batteries
Anyone here know the reason the “boost” setting isn’t used to charge a battery? The same reason for not using an alternator to charge a...
Sep 19, 2026
66Holiday924
1978 Islander 22 I/O
Building the lower deck I used aluminum slats for support, and I had enough 3/4" Coosa leftover to piece in. For the flooring I'm using...
Sep 19, 2026
