reacted to
drewm3i's post
in the thread
Maybe my turn for new boat time
with
Like
Surveyed one of these today! - it was a nice, well-made boat. Good quality construction, fittings, and rigging mostly - you will love...
Sep 20, 2026
replied to the thread
2026 - Mercruiser Cool Fuel 2 Module replacement
You don't have to to but you might want to. Once your down that far removing the 2 nuts that hole the entire assembly is easy and come...
Sep 20, 2026
HELP!!! Monterey 256 Sport Cruiser 1996
Glad you found it GLM is often called Good Luck Marine
Sep 20, 2026
reacted to
rickasbury's post
in the thread
Servicing my trailer bearings
with
Like
Sorry if it was not clear. Just like you might use an air compressor to push the piston out (which did not work), I put a grease zerk...
Sep 20, 2026
Wow that's a new one, glad you found it but what a bummer on all the time and money
Sep 20, 2026
Thunderbolt V question
Never understood it either. Used a vice grips or channel locks to snap the old rotors off. Never added loctite and never had a problem
Sep 20, 2026
reacted to
Lithrael's post
in the thread
Starcraft Holiday windshield advice?
with
Like
All right, so we ended up pulling all the clips out of the rails and setting them on the windshield in approximately the right spots...
Sep 20, 2026
reacted to
FLATHEAD's post
in the thread
Trail Cam pix......
with
Like
That’s an issue for sure. When you get in that area that’s between suburbia and rural you get a lot of folks feeding deer just to have...
Sep 20, 2026
Trail Cam pix......
Guy that's been studying ticks for years says each deer supports 3 million ticks each year
Sep 20, 2026
rickasbury
Sep 20, 2026
C
Crosbyman
Charging and tach issue. Voltage rectifier upgrade to 35amp?
DC volts/charge current come from rectified AC from stator so check if you have AC across yellows and stator coils are not...
Sep 19, 2026
drewm3i
reacted to
nola mike's post
in the thread
with
Like
Nope.
Sep 19, 2026
drewm3i
Anything this new on inboards will have cats sadly...they do cause hot-spots and some restrictions - more a maintenance issue.
Sep 19, 2026
drewm3i
reacted to
alldodge's post
in the thread
with
Like
If buying new I would not order the extended swim platform, but it's used so get what they have The motor is closed cool and uses the...
Sep 19, 2026
drewm3i
Sep 19, 2026
