Lou C
replied to the thread
4.3 Valve seals
That is pretty typical, my old cyl heads I'm sure would have been the same, so I would have had the machine shop do the valve job if...
Sep 20, 2026
D
DeepCMark58A
New project
Well I just need to do some more prep and clean up next weekend should have the new layer of plywood to the floor. Then the walls begin...
Sep 20, 2026
Lou C
4.3 Valve seals
Hard to say then, you'll get better results on a warmed up engine. One thing the owner should know, boats need more maintenance than...
Sep 20, 2026
J
jlh3rd
an almost stepson needs some advice
sorry...guess I didn't see the "non". And stated it was a late 90's Merc. 60hp 2 stroke....1996, I believe. Figured that mount is...
Sep 20, 2026
R
Repowering my old 16ft aluminum boat thinking of going 4 stroke but have a question
No such thing as a 2 stroke ( in good condition ) that is hard to start.----In my opinion most folks are unaware of how to maintain...
Sep 20, 2026
tpenfield
Servicing my trailer bearings
Is this a technique for pushing out a brake caliper piston? if so, I’m wondering about the grease remaining in the cylinder 🤔
Sep 20, 2026
A
airshot
Wow, two strokes are going for good prices, more than in my area. However when folks realize the repair costs if needed, they do tend...
Sep 20, 2026
J
JW Hall
MC1 Leaking gear oil from lower unit
I can't see a number on the plate where the serial number should be, the tag if there was one, is long gone and the housing has been...
Sep 20, 2026
redneck joe
any mod can you move to a repair section after we know what flavor of outboard it is. For the T&T, doesn't have to work if not out...
Sep 20, 2026
redneck joe
reacted to
Lithrael's post
in the thread
Starcraft Holiday windshield advice?
with
Like
All right, so we ended up pulling all the clips out of the rails and setting them on the windshield in approximately the right spots...
Sep 20, 2026
WIMUSKY
iboats Football Pick 'em is back!
I believe there is only one of us and I'm not thinking it's going to be very good day...
Sep 20, 2026
FLATHEAD
Trail Cam pix......
Seems like a lot. I will say every deer I’ve shot in the past 25 years had ticks. Strong dislike for those blood suckers.
Sep 20, 2026
A
airshot
reacted to
rickasbury's post
in the thread
with
Like
Sorry if it was not clear. Just like you might use an air compressor to push the piston out (which did not work), I put a grease zerk...
Sep 20, 2026
J
jase34242
reacted to
Bt Doctur's post
in the thread
2026 - Mercruiser Cool Fuel 2 Module replacement
with
Like
remove the fuel lines at the sep, remove the tbi/rail connection, remove the water line hoses,remove the 2 nuts 26 and remove the CF...
Sep 20, 2026
S
SeaRayboater95
4.3 Valve seals
Compression test was done on a non running cold engine.
Sep 20, 2026
