aspeck
reacted to
redneck joe's post
in the thread
2026 NFL/CFB News and Nonsense
with
Like
Sep 20, 2026
reacted to
Bt Doctur's post
in the thread
2026 - Mercruiser Cool Fuel 2 Module replacement
with
Like
remove the fuel lines at the sep, remove the tbi/rail connection, remove the water line hoses,remove the 2 nuts 26 and remove the CF...
Sep 20, 2026
M
Mc Tool
replied to the thread
Trail Cam pix......
Gee ! the weight alone would drag a deer down ....and the blood loss would be huge ....no wonder they raid gardens , they must be...
Sep 20, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
4.3 Valve seals
with
Like
That is pretty typical, my old cyl heads I'm sure would have been the same, so I would have had the machine shop do the valve job if...
Sep 20, 2026
aspeck
reacted to
FLATHEAD's post
in the thread
Trail Cam pix......
with
Like
Seems like a lot. I will say every deer I’ve shot in the past 25 years had ticks. Strong dislike for those blood suckers.
Sep 20, 2026
K
kenny nunez
MC1 Leaking gear oil from lower unit
You need sierra marine #18-2150 stainless steel shift shaft &18-7153 shift shaft bushing. Google mercruiser shift shaft bushing removal...
Sep 20, 2026
9
99yam40
New project
so you want to go outside in the freezing cold to take a dump and **** when you need to?
Sep 20, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Wood stove install
with
Like
my boat oil i take to where i get my oil changed. When we had the big boat, the marina let everyone use their tank. Back to my...
Sep 20, 2026
redneck joe
iboats Football Pick 'em is back!
just looked at all the 4th quarter possible upsets, there are several that could happen. 2% picked teams (like the titans)
Sep 20, 2026
redneck joe
RV build quality - Rant
you gonna OTF that?
Sep 20, 2026
redneck joe
Wood stove install
Sep 20, 2026
S
saltchuckmatt
Charging and tach issue. Voltage rectifier upgrade to 35amp?
All answers above are correct, but in case you don't know, voltage increase is slow. Alligator clip your probes on, fast idle and go...
Sep 20, 2026
9
99yam40
Servicing my trailer bearings
I agree. I would think contaminating the brake fluid system with grease is not a good idea
Sep 20, 2026
D
Donald0039
posted the thread
Engine does not seem to be pulling in water from muffs
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Had not been to be that in awhile and so I connected the muffs and turned on the water and as normal water shots out from the muff...
Sep 20, 2026
T
tphoyt
Wood stove install
Most auto parts stores will take it if you buy the oil from them and return it to them in the original containers.
Sep 20, 2026
