replied to the thread
1992 OMC 3.0 Cracked Block
Or the transom is rotten
Sep 21, 2026
reacted to
99yam40's post
in the thread
Servicing my trailer bearings
with
Like
I agree. I would think contaminating the brake fluid system with grease is not a good idea
Sep 21, 2026
reacted to
tpenfield's post
in the thread
with
Like
Is this a technique for pushing out a brake caliper piston? if so, I’m wondering about the grease remaining in the cylinder 🤔
Sep 21, 2026
reacted to
99yam40's post
in the thread
with
Like
did anyone understand what he was writing?
Sep 21, 2026
M
Mc Tool
Light corrosion in cylinder BF130
Dude , I know its not great but that rust aint bad compared to some I have seen . Honestly if that were mine Id tip a bit of oil in...
Sep 21, 2026
F
froggy1150
Restoring 1975 glasply 2300, bilge question...
I think this was the one. Not sure if it was this size or smaller
Sep 21, 2026
F
froggy1150
I fit mine to slide into the pvc stubout in the bilge. Made it fit barely snug then added a o ring. Screwdriver to pry out and a long...
Sep 21, 2026
B
boscoe99
Starting engines with jump box & dead house batteries
That seems contrary to a discharged battery having a greater current flow than does a fully charged battery. Where current flow is...
Sep 20, 2026
J
Jcgonzal
Well I figured I’d post an update on my progress. Got the engines swapped out, replaced both bellows and gimbal bearing while I was in...
Sep 20, 2026
N
Nordin
reacted to
Chris1956's post
in the thread
Any Ideas How to Get a Stubborn lower unit screw out:1990 15Hp
with
Like
Gee, I have been using a hand impact driver to tighten and loosen gearcase screws since the 70's. I never had a screw loosen up and...
Sep 20, 2026
R
runninfarmer
posted the thread
in
Honda & Tohatsu/Nissan Outboards
Hi, I have a 2000 BF130 that has 210-220 psi compression in cylinders 1,3, and 4, but 175 psi in cylinder 2. I scoped it and there is...
Sep 20, 2026
WIMUSKY
reacted to
Scott Danforth's post
in the thread
RV build quality - Rant
with
Like
Were we were just before putting the glue down and wrestling with the PVC membrane Then it rained. Will get more pics after it stops...
Sep 20, 2026
WIMUSKY
iboats Football Pick 'em is back!
Yup. I was happily surprised. Good Ds and the weather helped too. At the end I thought it was going to he another Michigan game when...
Sep 20, 2026
H
Harkonnen
R/V Port Yankee construction
Second half of August: Floppy hull assembled, removed from temp frames, and forced into alignment. Yes, 2x4 is crooked, but my real...
Sep 20, 2026
S
SeaRayboater95
Milky oil
That's what I thought. Thx
Sep 20, 2026
