J
jlh3rd
replied to the thread
Entire electrical system dies when under way
+1 on corrosion somewhere. I had a similar issue a year or so ago. It turned out to be a corrosion issue in the battery feed (wasn't the...
Sep 22, 2026
J
jlh3rd
Help Identifying Boat
chrysler motor, right?
Sep 22, 2026
J
jlh3rd
an almost stepson needs some advice
that's what I'd heard. So that's not gonna happen, at least from my end. But, as a last resort....anyone here able to give a rough...
Sep 22, 2026
2008 338 Four Winns
Unless there is something else like there was a lot of filings on the magnet I wouldn't worry about it. Don't know when the lube was...
Sep 22, 2026
C
Replacing the steering rod (actually swivel pin is it's official name) is a PIA. You pull the gearcase. You pull the powerhead. You...
Sep 22, 2026
B
Boaterdan278michigan
posted the thread
2008 338 Four Winns
in
Boat Topics and Questions (not engine topics)
We have an accepted offer on a 2008 Four Winns 338 vista. The boat has Volvo DPS-A outdrives. During survey we took oil samples from the...
Sep 22, 2026
redneck joe
reacted to
Harkonnen's post
in the thread
R/V Port Yankee construction
with
Like
If I could do it indoors, I would have done it indoors. :) Drought helps. I'll probably be ready to flip it again next weekend for...
Sep 22, 2026
redneck joe
Wood stove install
was thinking that yesterday. I will be burning some junk wood so i will need to keep clean. Against my need to have things...
Sep 22, 2026
redneck joe
Wood stove install
i've had part of my poop chute already from cancer out so i am well aware. I wear my belt low and have a pair of winter socks down...
Sep 22, 2026
C
Ignition Troubleshooting - 1978 700
Sounds about right. Those older Mercs had issues with insulation falling off the wiring harnesses. You might also look for that. CDI...
Sep 22, 2026
C
2001 Mercury 40 2-stroke Knock
The reed stops are real corroded. That should not be. The pistons look fine, from the angle of the photos. The top inside of the...
Sep 22, 2026
redneck joe
iboats Football Pick 'em is back!
welp...
Sep 22, 2026
C
Well, your electrical cables are likely not good, somewhere. Look for corrosion under the insulation. Check the battery switch for...
Sep 22, 2026
R
Pictures of the flywheel?----Serial # of the motor>----Pictures of top of pistons?----Checked the gear oil?
Sep 22, 2026
M
Mc Tool
Ok a question about points systems….
Check points gap too , to much dwell time can cause a coil to run hot .
Sep 22, 2026
